First tune. Opinions for the advanced?
Old Mar 26, 2010 | 01:44 PM
mitsuEVO8kid's Avatar
So I recently proceeded with starting to tune my car because I have been reading throughout the ECUFlash forums daily and have already learned a lot. After countless logs to verify, there was a ton of knock coming from the engine. So i decided to work my way slowly with the timing and then the fuel maps. I flashed my car and with the new logs, the knock seems to be gone. There is only a couple counts here and there, but nothing repetitive. The car seems to be running well and A LOT smoother.
I wanted some opinions (Constructive critisism is allowed) to see if this is a decent tune for my car. I drive a 2005 Evo 8 5 speed with ONLY a testpipe and cat-back exhaust. Sorry if the pic is a little big! and I apologize if these arent the best colors, it's just anything else I tried hurts my eyes
Old Mar 26, 2010 | 02:24 PM
EvoIan's Avatar
May want to attach some logs.
Old Mar 26, 2010 | 02:46 PM
ohhgyeahfasho's Avatar
+1. Attach some logs for us to see. Log the following TPS, RPM, 2byte load(or 1byte load), Knock Sum, Timing Advance, and WB02 AFR.
project_skyline's Avatar
Are you using a WB02 and is lean spool enabled still?
