aem widband and evoscan?
Old Mar 29, 2010 | 05:40 PM
Kevin Knight's Avatar
i though you log with a tratix cabel in the obdII spot when useing evoscan, but with a AEM wideband you have to use a serial port you make?? or do you hook up both at a time?
100% lost please help
Old Mar 29, 2010 | 05:51 PM
EvoJoeIX's Avatar
https://www.evolutionm.net/forums/ge...p-evoscan.html
Old Mar 29, 2010 | 05:52 PM
evokid511's Avatar
its easy just make the serial cable shown above and connect it to your computer the same time you are logging with evoscan.
Old Mar 30, 2010 | 09:10 AM
SeeCoryRun's Avatar
best way to log the AEM without running into serial cable issues is to log wideband via rear o2. i fought and fought trying to log via the serial cable with my AEM in evoscan and in the end it was easier and less clutter logging via the rear o2. ie you only have to hookup one cable to your laptop
https://www.evolutionm.net/forums/ev...ht=logging+afr
https://www.evolutionm.net/forums/ec...ht=logging+afr
Old Mar 30, 2010 | 05:18 PM
did you have a aem uego. and did you hook it up with evoscan?
Old Mar 30, 2010 | 06:52 PM
EvoJoeIX's Avatar
i have an aem wideband, but i never logged it using evoscan
Old Mar 30, 2010 | 10:10 PM
codgi's Avatar
To the OP the above link is more or less what you need to do. To answer your question directly if you want to log the UEGO using its serial output you will need to build/buy a cable to connect to it (some folks on here used to sell cables) and connect it separately to your computer.
Old Mar 31, 2010 | 04:52 AM
SeeCoryRun's Avatar
the issue i ran into with logging the UEGO with evoscan was the fact that evoscan couldnt read the UEGO correctly while mitsulogger read it just fine.
Old Mar 31, 2010 | 09:38 PM
codgi's Avatar
Some of the more recent versions of EvoScan had issues with the UEGO from memory. I still use a really old version which has worked fine for a couple of years .
darkmitsu
Lancer Engine Management / Tuning Forums
141
Dec 31, 2022 05:41 AM
Turtl
Jun 19, 2012 02:43 AM
Yamahar1
Nov 18, 2010 06:07 AM
wtf_is_a_evo
May 1, 2010 11:04 PM
Evo8uk
Sep 15, 2009 02:18 PM
