EcuFlash 1.42 not working, worked fine in Jan
Old Mar 30, 2010 | 06:23 PM
bboypuertoroc's Avatar
Veteran: Army
So, my car was flashed back in Jan with a valet map and shipped to me out here in Korea.
Same cable (1.3u), same laptop (HP mini with XP), same version EcuFlash, now doesn't want to flash back to my normal map (or anything else for that matter), also won't read from ECU. EvoScan works fine.
Any ideas?
Here's the error code from EcuFlash:
[08:13:29.843] 88590015 (88 tables) inheriting evo9base_20081101 (135 tables)
[08:13:29.906] 524288 byte image read.
[08:13:32.187] Using interface OpenPort 1.3 Universal TX2989Eo17cef6d5472e45b257fad2b58b7d0fe07ca53804
[08:13:40.875] sending init sequence 1 (0001)
[08:13:44.125] sending init sequence 1 (0003)
[08:13:47.359] sending init sequence 1 (FFFF)
[08:13:50.078] no response to any known code
[08:13:50.078] interface close
Tony (can't rev past 3500rpm, is sad in the pants)
Old Mar 31, 2010 | 02:10 PM
Veteran: Army
Bump... anybody?
Old Mar 31, 2010 | 09:42 PM
Veteran: Army
NVM... problem solved.
I originally tried the three fixes posted in the stickied thread to no avail. Ended up having to flash the car while it was running. Took several attempts to do this also... first time it started flashing but stopped at about 65% and said to restart the flash to complete it. Tried several more times until it finally finished the rest of the flash.
Pain in the ***, but it works.
GrabbinGears
Jul 7, 2016 02:19 PM
jgesler
May 24, 2013 05:02 AM
monkeyevo
Aug 2, 2011 01:52 PM
neonglh
Jun 6, 2011 03:19 PM
gilbertflores
Oct 13, 2008 05:34 PM
