I need help please!
Old Mar 30, 2010 | 08:59 AM
joshl'sevo8's Avatar
Question I need help please!
Hey guys, I could really use some help. I can read my rom from my ecu just fine and can edit it, but I cannot find or pull up my xml files to modify it for the mut tables. Also I downloaded tephra V7, but cannot get it to pull up in ecuflash. My metadata info in ecuflash will not pull up either, I can pull it up under the start menu of my computer but not ecuflash. I have tried everything and have searched on here for 3 days straight to no avail. Any help would be greatly appreciated thanks.
Old Mar 30, 2010 | 06:40 PM
rolly1818's Avatar
Registered User
lets deal with the first problem, you cannot find your xml?
Old Mar 30, 2010 | 06:54 PM
LGshow19's Avatar
-you need to take out your regular xmls first(i.e. whatever rom v7 is)..
-then you need to transfer the v7 xmls to the metadata folder...
-as for not seeing your xmls. You should have saved ECUflash to your desktop, so you can go to My desktop, ECUflash, rommetadata, mitsubishi, and evo. Then you can see your xmls.
