GM 3bar map sensor
Old Apr 3, 2010 | 10:36 AM
Keller's Avatar
GM 3bar map sensor
Hi I installed 3bar map sensor to 5V (A=ground , B=signal pin 73 on edm8 260,C=5V+)ecu supply but I got wrong reading from it...on engine off ignition on gives me 4,86V. Is this mean my sensor is f***t =cadunken?
Old Apr 4, 2010 | 03:59 AM
Keller's Avatar
Come on people ...any one ?5V go in 4,86 comes out no vacuum or pressure applied is this sensor bad or what?
Old Apr 4, 2010 | 07:41 AM
jrohner's Avatar
There are some 3-bar GM sensors that are wired differently, and it does sound like you may be wired wrong.
Old Apr 4, 2010 | 03:32 PM
Keller's Avatar
I did read about it somewhere but I can't find it where ;/
I would be grateful for any help ... I don't wont fry up ecu by trying hot wiring
THX in advance
Old Apr 5, 2010 | 02:10 AM
Keller's Avatar
I found this :
3 Bar MAP sensor wiring faq
Those purchasing new 3 bar map sensors from AC Delco part numbers 213-1562 or GM 12223861 the sensor is wired internally different than the original TTA 3 bar.
The correction involves swapping the power and ground terminals to it. Whereas old sensor wiring is
A= 5v
B=signal
C=ground
New wiring for 12223861 or 213-1562
A=ground
B=signal
C= 5v
Hope this saves someone from buying the GM harness that reverses the wires for 30 bucks
This only applies to 3 bar map sensor users
OneCrzyEvo21
Jan 7, 2015 06:31 PM
eyebrowski
Apr 24, 2010 06:41 PM
MR
36
Mar 27, 2010 10:51 PM
EvoCrazyyy
Feb 26, 2010 02:39 PM
mrfred
Aug 14, 2009 07:17 PM
