89960000 any info ??
Old Apr 26, 2010 | 10:17 AM
evo9_jdm's Avatar
Hello,
I have EVO 9 JDM my rom ID is 89960000 does any one have links or info on this rom ? I found the rom 89960000.exl on the web because at first I could not read my rom the problem is now I opened my rom and there is no mivec or mut table ?? It seams like an old xml and it is very hard to find info on JDM models.
If some one can help me please because like this I have no chance of mapping with out a mut table.
Old Apr 26, 2010 | 02:21 PM
logic's Avatar
The MUT table appears to be at 35920.
If anyone is in need of a copy of this ROM to play with, it's on the wiki. I've added the MUT table address, along with 2-byte RPM and airflow.
Old Apr 26, 2010 | 02:50 PM
Danieln's Avatar
Mivec is at "5a33"
Mut as logic said is at "35920"
What exactly you don`t see?
Since your rom is a JDM Evo 9 2005 the definitions needs some work a bit.
For example if you want to see the mivec map add this:
<table name="VVT Map 1 (Main)" address="5a33" category="Timing" type="3D" swapxy="true" scaling="ValveTiming">
<table name="Engine Load" address="6aa8" type="X Axis" elements="20" scaling="Load"/>
<table name="RPM" address="6ada" type="Y Axis" elements="16" scaling="RPM"/>
</table>
For MUT table add this on your xml definition:
<table name="MUT Table" category="MUT" address="35920" type="3D" level="2" scaling="Hex16">
<table name="X" address="50000" type="Static X Axis" elements="32" scaling="Hex16">
<data>-</data>
<data>0</data>
<data>-</data>
<data>1</data>
<data>-</data>
<data>2</data>
<data>-</data>
<data>3</data>
<data>-</data>
<data>4</data>
<data>-</data>
<data>5</data>
<data>-</data>
<data>6</data>
<data>-</data>
<data>7</data>
<data>-</data>
<data>8</data>
<data>-</data>
<data>9</data>
<data>-</data>
<data>A</data>
<data>-</data>
<data>B</data>
<data>-</data>
<data>C</data>
<data>-</data>
<data>D</data>
<data>-</data>
<data>E</data>
<data>-</data>
<data>F</data>
</table>
<table name="Y" address="50000" type="Static Y Axis" elements="30">
<data>MUT0X</data>
<data>MUT1X</data>
<data>MUT2X</data>
<data>MUT3X</data>
<data>MUT4X</data>
<data>MUT5X</data>
<data>MUT6X</data>
<data>MUT7X</data>
<data>MUT8X</data>
<data>MUT9X</data>
<data>MUTAX</data>
<data>MUTBX</data>
<data>MUTCX</data>
<data>MUTDX</data>
<data>MUTEX</data>
<data>MUTFX</data>
<data>MUT10X</data>
<data>MUT11X</data>
<data>MUT12X</data>
<data>MUT13X</data>
<data>MUT14X</data>
<data>MUT15X</data>
<data>MUT16X</data>
<data>MUT17X</data>
<data>MUT18X</data>
<data>MUT19X</data>
<data>MUT1AX</data>
<data>MUT1BX</data>
<data>MUT1CX</data>
<data>MUT1DX</data>
</table>
</table>
Old Apr 26, 2010 | 02:52 PM
Danieln's Avatar
MUT 00 = 6B12(2byte load)
MUT 01 = 6B13(2 byte load)
Old Apr 27, 2010 | 02:29 AM
evo9_jdm's Avatar
This is very help full thanks allot mates
Old Apr 27, 2010 | 02:44 AM
Danieln's Avatar
No problem.....
Old Apr 27, 2010 | 07:24 AM
logic's Avatar
Danieln, I added 2-byte load to the wiki, thanks for that.
Old Apr 27, 2010 | 07:40 AM
Danieln's Avatar
Most welcome mate...
mrfred
May 1, 2020 10:16 AM
mrfred
82
Jan 3, 2020 04:18 PM
2winscroll
Feb 16, 2017 01:39 PM
evo9_jdm
May 5, 2010 12:53 AM
EvolutinIX
Apr 1, 2010 05:48 PM
