Afr map ?
Old Apr 28, 2010 | 03:12 PM
evo9_jdm's Avatar
Afr map ?
Hello,
I just have a question I am logging with evoscan and I don't have an extra wideband like LC1 but in the EXL table that I have logged there is AFR MAP and numbers that look like AFR readings can I use this like the LC1 to map my Evo ? or do I need to buy a LC1 wideband ?
Old Apr 28, 2010 | 03:13 PM
Raptord's Avatar
The AFR MAP value is the value that the ECU is currently aiming for based on your AFR maps. It does NOT allow you to log AFR, you need a genuine wideband for that.
Old Apr 28, 2010 | 03:40 PM
tscompusa2's Avatar
dont try to tune with AFR Map its useless. you'd be better off using o2 voltage if anything. Get a wideband though.
Old Apr 28, 2010 | 11:16 PM
evo9_jdm's Avatar
Ya that's what I was thinking just wanted to be sure thanks guys
Old May 4, 2010 | 01:26 PM
evo9_jdm's Avatar
I just installed LC-1 and did calibration the LC-1 is working and reading fuel excellent in the LC-1 software I connected to evoscan and selected LC-1 and com port 1 the same port the LC-1 software is reading. Now my problem is Evoscan is not reading my fuel ??
Do I have to change something in the MUT table ?? my rom is 89960000.
Every thing is connected good like I am saying it works perfect in LC-1 software just wont work in evoscan that's were I need it working so I can finely map my Evo with ecuflash.
anyone ????????
philr8
May 10, 2010 08:21 AM
rogue
Mar 1, 2010 06:17 PM
evo8dad
Jan 31, 2009 03:48 PM
EVIL_EV0
Jun 6, 2007 07:34 PM
Evo Singh
Jan 9, 2007 10:09 PM
