LC-1 won't work with Evoscan ?
Old May 4, 2010 | 01:49 PM
evo9_jdm's Avatar
Hello,
I just installed LC-1 and did calibration the LC-1 is working and reading fuel excellent in the LC-1 software I connected to evoscan and selected LC-1 and com port 1 the same port the LC-1 software is reading. Now my problem is Evoscan is not reading my fuel ?? With my can turned on and off it say 13.85 AFR numbers do not move even when I push the throttle in LC-1 software they move and work perfect.
Do I have to change something in the MUT table ?? my rom is 89960000.
Every thing is connected good like I am saying it works perfect in LC-1 software just wont work in evoscan that's were I need it working so I can finely map my Evo with ecuflash.
anyone ????????
Old May 4, 2010 | 05:28 PM
Steed77's Avatar
Make sure you select LC1 in the W/B dropdown in the top menu bar. Also there is an option to pick the Com port for this sensor.
After I did that, mine was fine. I hope this helps.
Old May 4, 2010 | 05:40 PM
zeus1's Avatar
try what Steed77 said then if that does not work re-boot your laptop. i have had this happen and re-booting seemed to cure the issue, technically i have no clue but it worked. also do you have the other plug coming from the lc-1 capped? you need to do this to make it work properly. see below for what i am talking about
http://tunertools.com/proddetail.asp?prod=IN%2D3796
http://www.innovatemotorsports.com/s...C-1_Manual.pdf
Old May 5, 2010 | 12:53 AM
evo9_jdm's Avatar
Yes I checked com ports they are ok and I selected LC-1 I also did a reboot twice and connections are fine still did not work . I am running evoscan V2.6 in windows XP witch box should I select in evoscan ( external wideband A/F ratio ) ???? because the are 4 boxes with widebands just to be sure.
mrfred
May 1, 2020 10:16 AM
mrm95
11
Sep 7, 2015 06:40 PM
03Ev0luti0n
May 7, 2011 03:53 PM
saiyuke
Jul 6, 2008 01:13 AM
Evo Singh
Jan 9, 2007 10:09 PM
