SD to MAF help
Old May 8, 2010 | 03:56 PM
commodude81's Avatar
SD to MAF help
whats up guys well I was running SD for a bit but decided to run the MAF again. currently i have tephra mod v7 option 3, when i go into the folder and delete the SD part of it, it will not let me open the ROM without it. Is there anyway to just delete the SD part of the ROM?
Old May 8, 2010 | 09:00 PM
RoadSpike's Avatar
Changing the xml does not change the rom.
You should just copy a non SD rom and xml then copy your maps to it if you want to switch.
