need help mivec problems ?
Old May 6, 2010 | 12:21 PM
Egolution's Avatar
recently i change evo 8 engine to evo 9. with harness
and GSC S1 cams
i have DTC P1012. means V.V.T Cam
i dont know what is the cause of this DTC and how to fix
anybody have something similar and can help me?
Old May 6, 2010 | 05:39 PM
Gary@MellonRacing's Avatar
On this car i helped out we removed his evo 8 motor and installed an evo 9 motor and now we have this tiny issue , if anyone can help here we would appreciate it
Old May 6, 2010 | 06:10 PM
browningderek's Avatar
DTC P1021 oil feeder control valve circuit fault The control valve should have 6.9-7.9 ohms @ 68*F . Terminal 1 of the control valve should have B+ from the MFI relay. terminal 2 of the control valve goes to the ecu terminal #32.
so if the control valve ohms out ok. you have power to the valve @#1. turn the key on(engine off) and backprobe terminal #32 at the ecu you should have 12V there with the valve pluged in. if you valve is good, you have power to the valve and at the ecu with the valve pluged in.then i believe your ECU is bad. hope this helps........
Old May 6, 2010 | 06:33 PM
Thanks for the answer man , but we did that already
the issue is the code P1012
Old May 9, 2010 | 01:46 PM
todd6027's Avatar
mivec cam sensor faulty
Rado_93
Oct 23, 2015 11:48 AM
TheBoz
17
Jul 22, 2013 10:41 PM
browningderek
Oct 17, 2012 09:42 PM
BadazzCR
Aug 23, 2008 07:40 AM
EVOclub4
Jan 15, 2008 08:20 PM
