EcuFlash xml help. (Window Switches)
Old May 14, 2010 | 07:30 PM
Ceddy's Avatar
I'm adding Solenoid Window Switch Activation for my Mods for the 98/99 DSMs.
Does anyone know if its possible to have multiple scalings in one table?
Like:
FPS
RPM -> min, max
TPS -> min, max
Load -> min, max
Speed -> min, max
Knock -> min, max
Boost -> min, max
Could something like this be done by manually editing the .xml?
Also, when you open a table, there is Map Help in the menu.
Is this help/info that can added for each table?
If so, how do you add it?
--- Solution -> Add a <description> tag before the last </table>.
Also x2, when I View Graph, EcuFlash crashes...
This is on a new laptop with Windows 7. EcuFlash Version 1.43.3000
Is there anything that needs to be installed for graphing?
Or has anyone had same issue, know solution?
(I installed EcuFlash outside of \Program Files, to stop UAC issues.)
Update - A bad Axis scaling was causing crashes.
Old May 16, 2010 | 11:22 PM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Maybe we could ask Colby to create XSD?
It would save a lot of hassle.
