Question to Tephra and other mod makers
Old May 18, 2010 | 06:32 PM
RoadSpike's Avatar
Originally Posted by tephra
Oh I see..
Yes the "map switcher" included in the ROM is always Zero...
so yeh the first address should only ever be used...
Ok I'm thinking that's the issue i'm having in the lancer auto rom. I'll try putting in those weird axis tables at the end of the code and see if i get a better result.
Old May 18, 2010 | 06:36 PM
tephra's Avatar
The code that goes into that map switcher (the included one) should be pretty easy to follow back to the source...
If you want send me your current disasm (or just the ROM) and I can have a look
Old May 18, 2010 | 06:43 PM
Ceddy's Avatar
RoadSpike out of curiosity do the SH Auto ecus have the stock "Map Switching".
The H8 ecus have a second set of maps for most of the tables. (Fuel, Timing, Idle, etc.)
These are selected depending on the Shifter position. (P, N vs 1, 2, D, R)
Old May 18, 2010 | 06:54 PM
RoadSpike's Avatar
Sure pm me your email tephra and i'll send it on its way.
Old May 18, 2010 | 06:55 PM
tephra's Avatar
its <guess this part :P> at gmail dot com
RoadSpike's Avatar
I'm not really sure to be honest I haven't spent an epic amount of time in this rom but i can tell you it mimics scary close to the evo GT-A rom which does do that so I'm going to hazard a guess of yes it does.
Old May 18, 2010 | 07:06 PM
RoadSpike's Avatar
Gratzi email sent.
Old May 18, 2010 | 08:04 PM
RoadSpike's Avatar
Oh amusing tid bit that particular map switching address I guess is standard in all roms MUT table request 34.
Old May 19, 2010 | 11:19 AM
RoadSpike's Avatar
Special Notice to Tephra and other potential rom crackers.
Finally got the nerve to desolder and pick the 996 turbo ecu i have laying around.
If any of you guys want the rom Let me know. Its already posted in the tactrix general forum.
Old May 19, 2010 | 11:40 PM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Originally Posted by logic
Does anyone here use the Lauterbach simulator?
Yes, but mainly for disassembling complicated parts, that I cannot follow in my mind.
Old May 19, 2010 | 11:41 PM
acamus's Avatar
I have not noticed this, I will have a look eventually.
Old May 20, 2010 | 12:46 AM
GregM's Avatar
The Airtrek has one fuel and timing map for N, 1, 2 and another set for 3,4,5 gear.
Old May 20, 2010 | 06:50 AM
RoadSpike's Avatar
I looked and it does use that weird index table of size 8.
I guess its a switching map but likely remains 0.
I haven't taken the time to see if mut request 34 changes at all
Decil
Apr 21, 2017 12:28 AM
jamie_v1
Feb 14, 2010 09:03 AM
SpyderBite
Apr 21, 2009 01:30 PM
