EZ question - How do you tell if the BCS is working?
Old May 21, 2010 | 02:52 PM
4DOORGALLOR's Avatar
I recently added a boost gauge and found that my new (used) evo9 was not boosting more than 10psi. I did a boost leak check and the car held 26 psi before the DV started to leak.
I then pulled the vac line off the wastegate actuator and was able to boost well above 20psi (controlled test).
I double checked my vac line routing from the BCS to the turbo outlet and actuator. I ensured the pills were installed correctly. I suspect the soliniod has failed.
Is there a way to test the BCS via volt meter with the car at idle?
Old May 22, 2010 | 09:06 AM
jy951's Avatar
You can probably check the resistance with an ohmeter, I don't think voltage will tell you anything. I'd check mine, but I don't have my Flukes wth me.
