EvoScan Boost (MDP) Logging
Has anyone had any issues logging boost using EvoScan 2.6? Mine seems to be logging boost at double and then some. The PSI it's logging is 47 PSI on a stock IX turbo. I'm using a Dell Inspiron Mini Netbook and Tactrix 1.3U cable to datalog. I thought it might be a Windows 7 issue but I get the same result if I set up the program compatability to Windows XP with service pack 3. Wanted to see if anyone has had any experience with this before I log a support ticket with EvoScan.
Evoscan is simply logging voltage thats why all the formulas are different for each sensor. MDP can only read up to 2psi which maxes out the sensor to 5 volts. This is why when you log a 4bar sensor formula with a mdp sensor you get 47 psi at boost.
RA09
10
Feb 4, 2013 09:19 AM
