Evoscan disconnecting at WOT???
Old Jun 1, 2010 | 07:40 PM
elhalisf's Avatar
I am having a problem with Evoscan. It will log just fine under idle and cruising and a little bit of boost. But as soon as i got into WOT, evoscan will disconnect from the ecu. It will auto reconnect when i am not on WOT.
Any suggestions on what could be wrong.
Old Jun 1, 2010 | 07:47 PM
nothere's Avatar
is your wideband staying on during wot?
try do a log without the wideband connected
Old Jun 1, 2010 | 07:48 PM
elhalisf's Avatar
well, it happens if i have the wideband connected or not. but when it is, it stopps logging the WB.
Old Jun 1, 2010 | 07:52 PM
PaperClip's Avatar
i think that means you have too much power lol
Old Jun 1, 2010 | 08:00 PM
dyezak's Avatar
You scared EvoScan. Apologize to it, console it, and try again.
Old Jun 1, 2010 | 10:06 PM
03EVOGUY's Avatar
Old Jun 1, 2010 | 10:25 PM
Evoryder's Avatar
I have the same problem with my Mitsulogger logging my zeitronix wideband /egt/boost. When I use mitsulogger and the zeitronix logger as separate programs no issues.
Old Jun 2, 2010 | 09:27 AM
elhalisf's Avatar
it happens even when i am not using my zeitronix.
Old Jun 2, 2010 | 09:25 PM
codgi's Avatar
Are you logging with a laptop? Can you get a 2nd person to hold the laptop specifically the connector to the cable?
Old Jun 3, 2010 | 12:30 PM
elhalisf's Avatar
Tried this on a friends car, with the same results. i even updated the evo scan software with no change as well.
Old Jun 3, 2010 | 12:47 PM
nothere's Avatar
did you try a different cable?
Old Jun 3, 2010 | 01:07 PM
elhalisf's Avatar
no i havent because i dont have acess to another one. but why would it be the cable?
Old Jun 3, 2010 | 02:13 PM
nothere's Avatar
can't help but think there is a connection that is intermittent
Old Jun 3, 2010 | 02:48 PM
fryedchikin's Avatar
Sounds like you have ruled out an issue with the car so that leaves Software,Laptop and Cable. I would try Mitsulogger, if still the same thing happens then try a different Laptop.
Old Jun 3, 2010 | 04:53 PM
gsxwingz's Avatar
Hey Faisal,
This is due to your Hard Drive motion detection. Go into start menu find toshiba hdd protection, and disable it. Rev2.7 gets rid of this problem.
