How rich it too rich?
Old Jun 4, 2010 | 10:03 PM
jasnm21's Avatar
Old Jun 4, 2010 | 10:05 PM
tscompusa2's Avatar
Theres a lot of ****ty tuners that should not be allowed to tune cars. The only respectable email tuner I like is Mellon.
Old Jun 4, 2010 | 10:37 PM
JohnBradley's Avatar
I dont have firsthand experience with 91 octane and some of its "habits" so I cant comment one way or the other. I have tried mixing 89 and 92 for guys that are going to CA (should be 90.5) and other than it doesnt like timing it seems to be the same as any fuel I have encountered.
Per 12:1 and road racing. Works great for 15 minutes and then the heatsoak and mildly increased EGTS seem to start knock issues on straight pumpgas. You might get one 20 min session and then its gonna happen on the next one (based on our resident course guy). He adds a pint of Torco and gets the octane to mid 90s (from 92) and is good for a few more sessions before it becomes needed again and he has to add some more race gas concentrate (the torco).
I didnt get the full rundown from Tahoe55 after the last track day when we tuned him for 11.0 as far as knock but the car was still plenty hot on the EGT front and was loosening turbo bolts and ate a gasket. Gas in general seems to run so hot its amazing that cars can go so long in endurance races without turbo or engine failure. I am thinking of cars like the Audi 4.0 FSi motors running 12.2:1 and 20psi on 100 octane ELF. I know they tune the decel fuel and use it to keep the turbos cooler. We can do the same thing and get the best of both worlds, well on the IX anyway. Besides everybody loves flamethrowers right?
Old Jun 5, 2010 | 12:58 AM
EvolutinIX's Avatar
Thanks for the feedback guys, sorry I can't figure out how to get my logs up, I know that's sad. Now I took a look at my low octane map and is is anywhere from 0.2 - 1.1 leaner than the high octane map....uh okay, this is why I am learing to tune my baby. I thought that there was no way 3* was causing the knock but I guess I'll back it down a degree and see what happens. As far as correcting the low octane map half and afr point richer should be safe, correct?? Oh man now I don't know if I should just put the stock maps back on, and start all over, or keep going on the ones I have, any more thoughts would be great...I need a beer.
Old Jun 5, 2010 | 06:08 AM
Mellon Racing's Avatar
thanks bud
Old Jun 5, 2010 | 12:02 PM
SWOLN's Avatar
*tip toes in to hijack a little* Can anyone comment on the ARF (93 and E85) for a Road Race tune and the timing as well? Thank you.
Old Jun 5, 2010 | 01:47 PM
EGTS are so low on E85 in general I tune it like we do for drag racing. High 11s and 2* back from MBT (typically 16-17*) to account for heatsoak. Alot depends on overall combination but JID2's car is a good example of what I mean. He had mostly street tuned it, we threw it on the dyno for a freshen up and giggles. The next day he was racing it on the track at 500whp and more or less what I just outlined.
I normally see EGTs somewhere around 1050-1150 in a pull it seems.
Old Jun 5, 2010 | 02:55 PM
Jack_of_Trades's Avatar
Wow, that is fairly low.
Old Jun 5, 2010 | 07:56 PM
Yeah E85 seems to be alot more akin to diesel for EGT than gasoline. I attribute most of it to the quantity of fuel being consumed and the ability to use great timing at high boost. E85 on a 12.0 gas scale is more likely something like 7:1 or whatever on a true lambda scale.
The hottest I think I have ever seen an E85 car is 1400s....maybe? I have never made a thin wall header glow on E85 so its not too warm. My car for instance can start a pull at 172* and end a pull at 172*....at 600whp. E85 is pretty awesome really.
Old Jun 7, 2010 | 12:32 PM
charlie.tunah's Avatar
3 could definitely be too much on crap 91. Im restricted to 91 and Im pretty sure im running close to 0, maybe 1 deg at peak torque (23 psi on the stock '05 turbo and low 11s afr). Every car and gas station are different. If its knocking (real knock, not phantom knock) with a reasonable afr, pull a degree of timing. Ive got my low octane map about a full point richer. But Im still learning as well. good luck.
Old Jun 8, 2010 | 01:31 AM
EvolutinIX's Avatar
Thank you for the input, I am at a loss. After really looking at my tune it went from a stock, too rich and too aggressive maps to even more rich and aggressive. I thought a good place to start was to lean the stock map but my high octane map is almost a full point richer everywhere than the low octane map which was not touched at all. I think I am going to go back to the stock fuel map and take it from there, anyone else have any ideas?
Old Jun 8, 2010 | 06:20 AM
tscompusa2's Avatar
if you want some assistance getting your afr good just give me a pm, ill get you goin the right direction.
Old Jun 10, 2010 | 11:20 AM
EvolutinIX's Avatar
Gettin everything dialed in great, I leaned it out a bit up top to hit 10.9 afr. Honestly I think changing fuel is what caused it. I used to only put chevron but in my area they went under so I had to swith to Phillips 66 and the fuel does behave differently. Thanks again for the help fellas, anyone else notice different brand of fuels being more "high maintenance"?
Old Jun 10, 2010 | 11:29 AM
dahuii77's Avatar
rich = backfire=flames
Old Jun 13, 2010 | 12:32 PM
SoCal Rally's Avatar
I prefer my car to have a conservative tune on mediocre 91, rather than a ragged edge tune on the best brand fuel. That way there's always a little bit of safety margin, and I never have to worry about filling up at a particular station, or with a particular brand of fuel.
4b11slayer
Nov 1, 2016 02:38 PM
grim~
Dec 29, 2011 07:14 AM
mac214
Mar 18, 2009 02:33 PM
nj1266
Jan 17, 2008 08:08 AM
nj1266
Oct 13, 2007 04:09 AM
