Anyone hopping on a Dyno very soon?
I'm desperately ooking for some good datalogs while strapped on the dyno to compare with the UNcorrected dyno results. Lemme know and I can tell you the info I will need about your car and possible about the dyno's parameters. If you have old datalogs while getting dyno tuned and still have the dyno results (UNcorrected please), I can try that as well. The only catch, the datalog should be from the exact some pull that the dyno printout was from for the best accuracy.
Thanks fella's!
Thanks fella's!
Just curious, how do you plan on comparing the dyno plot to the VDR results and then applying it to how it works on a street pull?
You are accelerating the dyno load on one pull and the car on the other?
After that, I just try to compare street pull logs from the same car and make sure they reflect nearly same figures when loaded into VDR vs. the real dyno. The more dyno's I get data from, the better I can create an average scaling for a particular dyno 'type'.
Dynojets are the most repeatable from one shop to the next but Mustang dyno's have a great deal more HUMAN entered data so there can be greater variances from one shop to the next.
Here is one sample of datalog data vs. exported dyno plots.
Dynotech Tuning
Evo X Dyno Results
50
Feb 27, 2012 08:13 PM
Don Q
Apr 1, 2011 12:21 AM
EVO8LTW
Jun 21, 2009 08:28 PM
