How are u guys launching with V7 launch map
Old Jun 10, 2010 | 12:25 AM
GotWheelHop's Avatar
I can build 22-25psi in about 2 seconds on launch maps. 7.4 across the board for afr, and -10 timing, at 6250. It also shoots one hell of a fireball. I wouldn't dare to launch at that kind of boost though.
Real world conditions, fuel map is set to about 10.5afr, with 5 degrees advance. 5900 rpm. I get minimal boost at launch, but the shock to the driveline is minimal also.
*edit* I don't just mash it, I blip to get the rpm up, then mat the pedal once I get to about 5k
2.3 stroker, with a gt4088r.
Old Jun 10, 2010 | 12:15 PM
ant_turbo's Avatar
So how are these settings worling for u,,, Can u please show ur map,,
Thanks..... What psi are u htin.
Old Oct 12, 2010 | 07:39 PM
04EBevo's Avatar
timing is at -6 and I make about 18psi and can get a 1.6 60 on street tires. After 4 of those passes I had to send my tc to shep.
Old Oct 16, 2010 | 08:40 PM
mt057's Avatar
Lol were you slipping the clutch it just dropping it? I was thinking about trying it out, but I might wait a little more...
Old Oct 16, 2010 | 09:15 PM
04EBevo's Avatar
I slipped it but then again there isnt much slipping going on with an act 6 puck
Old Oct 17, 2010 | 06:15 AM
mt057's Avatar
I was considering that clutch next as well ... I think I might just cough up the dough for a twin disk. I have launched many times but not with the launch maps.
Old Nov 1, 2010 | 03:54 PM
widge's Avatar
Kinda old thread but i want some launch map configs, im at about -10 timing and 9's AFR and when i launch i bog then wheel spin, need to get it right so i can head to the track for my first time
Old Nov 1, 2010 | 05:20 PM
04EBevo's Avatar
What rpm is it set at?
Old Nov 1, 2010 | 05:29 PM
widge's Avatar
5500rpm at the moment, it kinda bogs then wheel spins
Old Nov 3, 2010 | 10:00 PM
04EBevo's Avatar
I would give 6000 a try as that is what I see alot of successful setups doing. That 500 rpm can and will make a difference.
Old Nov 5, 2010 | 06:21 AM
CammedEvo's Avatar
logg the cells your hitting..
make your launch map transition to your regular timing map../fuel map gl...
Old Nov 10, 2010 | 02:04 PM
widge's Avatar
Ill increase it to 6000rpm and have a go over the weekend
How do you make the transition smoother from launch maps to normal maps, i mean how can going from -10 to say 15 be smoother?
Using the above as an example
Old Nov 15, 2010 | 08:44 PM
Chameleon@NLM's Avatar
buuump for discussion..
Old Nov 16, 2010 | 07:52 AM
Spec-Ops1's Avatar
Bumping as well... To add some data...
We were trying to get the car to carry the launch map thru all of first gear and then get it to transition on shift to 2nd. Still didnt have enough time to dial that in but it seemed as we were getting closer. The other thing we tried doing was to run the car a little leaner on launch, to the point of no knock, but borderline. The problem that occured was of course the car was getting hot and then we'd experience knock thru the pass and it wasn't worth it. In the end we reverted back to the standard 2 step until more testing can be done.
If there is anyone that has got something that is working, share the wealth
Old Nov 16, 2010 | 01:40 PM
widge's Avatar
+1 for sharing, i cant get the car to not knock on launch map, and as above its not worth it as it stuffs the whole pull.
I have also gone back to the stock stat rev limit for now
