TephraXMOD V1
Old Jun 11, 2010 | 10:28 AM
  #46
Guru's Avatar
Donation of $30 sent to Tephra! Haven't downloaded it yet but the knock CEL is a welcome addition. Not sure if I'll do an alternate map. Maybe race fuel map?
Old Jun 11, 2010 | 10:29 AM
  #47
bwagner31's Avatar
i see. next question, how will the knock light work if my ses is already illuminated due to being catless.
thanks for the help guys.
Old Jun 11, 2010 | 11:40 AM
  #48
newcomer81's Avatar
Originally Posted by tephra
I put a wiring digram for AEM/HFS/CM on the first page..
HFS/CM is a better failsafe method, AEM requires extra relay
if anyone has questions regarding the CoolingMist setup let me know. i have tested and verified it 100%
Originally Posted by murlo26
I don't believe he has gear based MIVEC in this yet. I think Gunzo did that though, so you could probably incorporate yourself.
I've already asked!
it will still flash, at least it did in early releases. fixing the catless cel is pretty damn easy though.
Old Jun 11, 2010 | 11:56 AM
  #49
newcomer81's Avatar
this came up on the other forums regarding the meth fail safe function and i thought i'd add it here as well
Once the ecu pin is grounded AND you are BELOW the load threshold the defined counter begins. once the counter reaches its value alt maps active.
my settings
switch:4
load:100
timer:3000
so if my meth kit give the "ok" by the fail safe wire being grounded and i am below 100 load for 3 seconds my meth tune turns on.
if at any time my failsafe is activated (ground removed) I INSTANTLY switch to my standard pump tune. a ton of fuel is added, timing is pulled and boost drops to safe 93 octane levels. I will remain on my 93 pump tune until my meth kit gives the "ok" again (by turning the ground back on) and i am below 100 load for 3 seconds. this is because if your doing a pull it will switch to the safe map until your off the throttle preventing the maps from toggling back and forth
how ****ing cool is that?
<3 ya T!
Old Jun 11, 2010 | 12:35 PM
  #50
newcomer81's Avatar
better pic of the wire for the meth failsafe
Old Jun 11, 2010 | 04:45 PM
  #51
Clipse3GT's Avatar
David,
So I switched everything over to the latest version you sent us / posted on evoM. The map switching for cruise control does not work now... it will not switch maps to the alt. There is no indication from ICS light. I tried messing with time settings and no map switch. The previous version worked... this one does not.
not sure what is going on.
I tried twice... to copy everything over and change... still no map switch...
Old Jun 11, 2010 | 05:41 PM
  #52
tephra's Avatar
You must be doing something wrong because other ppl say it works!??!
Old Jun 11, 2010 | 05:43 PM
  #53
tephra's Avatar
Thanks Guru
Old Jun 11, 2010 | 09:00 PM
  #54
Golden's Avatar
Clipse, mine works just fine on 55570106 rom (aka Tephra's 55570006).
Do you have the Alt-Map Load Threshold set low? I know I made that mistake. Make sure it is set to ~100. You must be under that load for it to work.
Maybe send your ROM to Tephra to have a look.
Old Jun 11, 2010 | 10:32 PM
  #55
Poondoggs's Avatar
Tephra, your money is coming in the next couple days, thanks!
Old Jun 12, 2010 | 02:14 PM
  #56
Jim in Tucson's Avatar
Sorry for thread jack...
If your coming from Evo 7-9 you may notice that there is a slight difference in the algorithm. NOW the CEL lamp will only flash when the knock STARTS above the thresholds. I have done this to stop low load knock from causing the CEL to flash when you pass above the load threshold.
Dave,
Any chance this revised CEL algorithm can be added to the Tephra V7 for VIII's and IX's?
Old Jun 13, 2010 | 02:18 AM
  #57
therocket's Avatar
Originally Posted by Golden
theRocket:
Definitions for "Cranking enrichment IPW adder" is on the first page.. like 3rd post.
Ops... thanks, didn't see it
Old Jun 13, 2010 | 07:29 AM
  #58
tephra's Avatar
2010 USDM GSR ROM tested and uploaded.
Thanks Golden for testing
BTW - Thanks to a BUNCH of guys for testing 2008 USDM GSR as well
Old Jun 13, 2010 | 01:37 PM
  #59
criptballer's Avatar
any word on gear based mivec yet from you tephra? that would really help out the aftermarket turbo people here, like myself
Old Jun 13, 2010 | 02:48 PM
  #60
Kracka's Avatar
Maybe I'm just retarded, but what is your Paypal address? I tried paypaldonations@globalshare.net and it says that address is not a registered user.
