Just discover that Timing maps are baro compensated!
Old Jun 29, 2010 | 10:09 AM
Carloverx's Avatar
can anyone tell me exactly what sensors/methods the car uses to detect baro and temp?
Old Jun 29, 2010 | 10:37 AM
l2r99gst's Avatar
If you're running the MAF, the temperature and baro sensor are in the maf.
Old Jun 29, 2010 | 10:39 AM
Vigman's Avatar
...and you just have to log them with evoscan.
Old Jun 29, 2010 | 10:55 AM
Carloverx's Avatar
Thanks for the info. I'm having ECU issues and i suspect it's either in my maf, or lean spool settings. Car suddenly jumps off tune and runs rich under heavy loads.
Old Jun 29, 2010 | 02:12 PM
Vigman's Avatar
Check electric connections. It looks like a a false contact.
Old Jun 29, 2010 | 02:55 PM
Jack_of_Trades's Avatar
Originally Posted by EvolutinIX
I have been having a similar issue. Elevation here is about 5800 feet. At wot the timing in my logs match my map but at 30% throttle in the 60 - 140 load area the timing is way off, how do I compensate for this?
This is most likely due to your EGR timing adjustments in that load range.
Old Jun 30, 2010 | 11:27 AM
EvolutinIX's Avatar
How would i overcome this, or do I just have to live with it?
roni4g63
Nov 14, 2015 11:45 AM
iowa_guy
Sep 21, 2011 02:32 PM
Appauldd
Aug 28, 2010 06:47 PM
Carloverx
Aug 27, 2010 04:03 PM
Seijuro
Mar 20, 2010 11:53 AM
