Maptracer not working
Old Jun 15, 2010 | 09:01 PM
Mark14's Avatar
Ok guys I have logged a few pulls and can't get maptracer to work correctly. It will pull up the graphs easily but won't transfer over to tracer. Also, when i look into rommetadata I can't find any rom id's i've flashed with Ecuflash?? Any help would be appreciated.
Old Jun 16, 2010 | 01:09 AM
drifterific's Avatar
From what I understand is map trace is not a "live tune" like you would see in megasquirt, aem, powerfc and many other ecu.
In evo scan what you do is you start your log, do your run and then click on "Graphs & Map trace" then click on real time logging and then at the bottom you will see where it says live map. So click on that and then load up the log and then load up your rom.
To see what your rom is ( you will be looking for the bin/hex file) you can open up ecu flash and look at the internal id under rom info.
Old Jun 16, 2010 | 04:21 PM
Mark14's Avatar
Have tried this all evening and still doesn't work, are there any links to tutorial on the tracer??
Old Jun 17, 2010 | 09:10 AM
Mark14's Avatar
Does anyone on here not know how to use map tracer??
Old Jun 22, 2010 | 08:22 PM
Mark14's Avatar
Ok I actually figured it out on my own, had to go back to 1.3. For some reason I haxe two new 2.0 cables that don't want to work.
Siege
Oct 24, 2016 08:06 AM
EvilEvolution8
Dec 22, 2015 05:26 AM
06EvoIXmr07
Nov 3, 2010 10:45 AM
ouminan
Jan 21, 2010 08:19 AM
nitz
11
Aug 13, 2009 06:50 AM
