Airtrek XML definition wanted
Old Jul 7, 2010 | 06:07 AM
ecktt's Avatar
Anything? I managed to pull the ROM from another friend's Airtrek via the exact same methond. We'd really like to remove the speed cut and retune for our pump 91.
Old Jul 7, 2010 | 06:08 PM
clck's Avatar
You can use everything from GregM, rom and xml files
If you do that, only require to change the following in his xml files:
<flashmethod>mitsukernelocp</flashmethod>
to
<flashmethod>mitsukernel</flashmethod>
Old Jul 9, 2010 | 06:03 AM
ecktt's Avatar
He didn't post his rom.
I tried replacing the stock xml in the airtrek folder with his and that still wouldn't open the rom. Any suggestions on how to go about this?
Old Jul 9, 2010 | 12:19 PM
GregM's Avatar
no point using my rom, and not sure if you should put the 89970010 rom in your ecu, as I know nothing about your rom. I'm assuming compatibility, but can't guarantee. Its up to you if you try, but if you want the stock 89970010 rom to try, let me know and I can send it to you.
I also tried opening your rom various ways and was unable to.
Old Jul 9, 2010 | 10:08 PM
clck's Avatar
89970009.xml
With this, you should be able to view your rom.
File Type: zip
Old Jul 10, 2010 | 05:23 AM
ecktt's Avatar
Whoa!
You're awesome.
Thanks for all the help guys.
Old Feb 26, 2014 | 01:37 AM
yskyes's Avatar
Hi,
any one can help me,
i can read from ecu using the ecuflash but cannot view or edit.
The pop-up come out after finish reading from ecu, (unknow rom image).
http://i1355.photobucket.com/albums/...ps10c189d1.jpg
How to get the right defination rom for it?
My ecu have been reflashed by tuner last time.
Thanks for help.
Old Apr 3, 2014 | 01:28 PM
nikush's Avatar
You have no XML files for this rom.
Old Apr 4, 2014 | 03:23 AM
yskyes's Avatar
Hi,
i had try many XML file but can't open it also..
This is my image file, can anyone help me to find the XML file, Thanks a lot.
https://www.dropbox.com/s/k9fet2ey4v...0image%202.bin
Old Oct 8, 2019 | 02:25 PM
ecktt's Avatar
Trying to disable the front o2 heater circuit code p0135 but the ECU periphery FAA does not seem to have any impact. Any advice?
Old Oct 9, 2019 | 11:45 AM
nikush's Avatar
post your Rom file i'll see
Old Aug 22, 2021 | 09:15 PM
ifti's Avatar
P0403 Exhaust Gas Recirculation (EGR) Control Solenoid Circuit Fault code
Hi there,
I have disabled the EGR in the original ecu, and downloaded the file to ecu. When I started the car, the check light ON.
Evo scan gives the following error;
-P0403 Exhaust Gas Recirculation (EGR) Control Solenoid Circuit as shown below
I than downloaded a file that had egr disabled from forum and downloaded this file to ecu. Still the check light was on with following errors
I have attached the file that is downloaded to ecu.
Any help will be much appreciated.
Old Aug 23, 2021 | 02:11 AM
nikush's Avatar
Try.
File Type: hex
Old Aug 23, 2021 | 02:18 AM
OzAirtrek's Avatar
That file originally has the EGR bit enabled-just the EGR tables are zeroed out. If you change the bit to turn off the EGR totally (which you have in your file) you will get a check engine light. Is your EGR hardware removed? because i dont think you can get around it - which i why in the original file the bit is still set at 1
Old Aug 23, 2021 | 03:02 AM
ifti's Avatar
Thanks.
I have downloaded the file you sent me but still same error.
I have removed all the hardwire meaning ERG, boost and FPR solenoids and their wires are not connected to anything
