Closed loop lt trim controls
Old Jul 3, 2010 | 07:39 PM
tscompusa2's Avatar
I cant for the life of me remember how this damn thing works.
Low -> Mid = is the transition from low trim to mid trim
Mid -> Low = is when the car is idling ........
Now what im confused about is this.. If the mid to low is when the cars idling and supposed to be in closed loop, what do i want that number to show in the trim table? Do I want to raise the Mid -> Low to be OVER the Hz of what i idle at or do I want it to be below?
Thanks
Old Jul 4, 2010 | 02:07 AM
tephra's Avatar
no its just switch points..
so when your in low - what mafhz does the ECU need to see to switch to mid
and when your in mid, what mafhz does the ECU need to switch back to low...
its just to stop the ECU from switching between LT trims to quickly...
Old Jul 4, 2010 | 02:13 AM
tscompusa2's Avatar
ok well I remember I had to either raise or lower one of these numbers to get my low fuel trim to start adjusting.. so that is the main reason i asked. If i am idling at a higher hz then whats set in that table I want to raise it so its not over right?
Old Jul 4, 2010 | 07:25 AM
tephra's Avatar
yeah exactly...
ecktt
May 8, 2017 06:18 PM
Raceghost
Dec 15, 2016 02:54 PM
edsct9a
Jul 26, 2016 01:41 PM
Appauldd
Sep 21, 2015 08:39 AM
ridenrunwv
Aug 20, 2015 07:19 AM
