Ajustments after cam install?
Old Jul 14, 2010 | 11:50 PM
EvolutinIX's Avatar
I have searched and searched but can't seem to find what I'm looking for. This weekend I will be installing GSC S1 cams, and would like to know where to start tuning them. Do I need to increase fuel due to more airflow and pull timing due to increased ve? Right now I have basic bolt ons, will be running 91 octane fuel and between 21 and 22 psi. I don't want to blow anything up on the first wot run after the install and need input on a starting point? Any advice or input would be great, thanks in adance.
Old Jul 15, 2010 | 12:50 AM
nonschlont's Avatar
I havent upgraded cams yet, but from what I understand, u need to bump up the timing in the idle area, bump up the idle a bit, to get them to idle better. I here those cams idle *almost* like stock. And yes, I think it would be a good idea to lower timing a couple * . I would think ur gonna need to re-do the mivec map as well.
GL
Old Jul 15, 2010 | 01:01 AM
EvolutinIX's Avatar
GL
Right now I run 7* at idle and use the JDM MIVEC map. Do I need to increase the fuel as well? As for timing though the rpm band do I want to pull a few degrees everywhere, or just up top?
Old Jul 15, 2010 | 01:09 AM
nonschlont's Avatar
Im guessing, but ~ 9-12* @ idle, not sure on fuel, and I would say yes, pretty much everywhere, for starters, just to be safe...
Old Jul 15, 2010 | 01:24 AM
EvolutinIX's Avatar
Sounds good, so if I pull 3* all over than i can take the same mtbt approach I have been? I also like the lope at idle, I know it won't be very noticable on such a mild cam but if I leave idle at 7* and have a little lope will it hurt anything. I don't really care about wasting gas, cmon I drive an evo.
Old Jul 15, 2010 | 01:28 AM
nonschlont's Avatar
nope, if u like the lope, leave the timing lower. I would start w/ 7* and see how they are...
Old Jul 15, 2010 | 05:39 PM
EvolutinIX's Avatar
Thanks for your help man, I know this is a noob topic and I didn't know if anyone would reply. Thanks for taking the time to post, any other pointers you can think of when adjusting timing after the install?
Old Jul 15, 2010 | 07:22 PM
hediki12's Avatar
are you talking about spark timing or mivec timing?
if your talking about ignition timing leave it if your talking about mivec timing i have not a clue... sry. hope some one can chip in.
Old Jul 15, 2010 | 08:30 PM
EvolutinIX's Avatar
Ignition timing, I'm gonna stick with the jdm mivec map. So if your stating to leave timing alone then what changes do i make after installing the cams, now im confused...
Old Jul 15, 2010 | 09:39 PM
hediki12's Avatar
i mean leave the timing alone in the wot section if its not knocking then your fine. if you want to see if the cams will allow you to add more timing then that's up to you. but cam timing/duration has no relation to spark ignition.and raise in idle 7-9* as some one said.
Old Jul 16, 2010 | 11:50 AM
Boosted Tuning's Avatar
Its MBT not mtbt. Also the MBT method doesnt work on 91oct as that it is a "knock limited" fuel.
Old Jul 16, 2010 | 11:23 PM
hediki12's Avatar
yea i was gonna correct that but i thought "mtbt" was a mivec terminology haha.
Old Jul 16, 2010 | 11:59 PM
EvolutinIX's Avatar
I do know you are probably better at tuning than I, but I was really looking for input on adjusting the timing after the cam install, not correction on my acronyms. Maybe I read it wrong but I was referencing the How to tune an Evo thread by nj1266.
Originally Posted by nj1266
My approach to timing is to follow the MTBT method, i.e., Minimum Timing for Best Torque. Simply stated, the method declares that a tuner should advance timing until advancing the timing no longer yields gain in power/torque or, lacking a dyno, until knock is encountered. On the last Evo 9 that I tuned, 1* beyond 10* at the top end and the car started registering 2-3 counts of knock. So I backed the timing from 11* to 10* and stopped tweaking the timing map.
NB: The method outlined above to setting the timing ONLY applies to 91-93 octane gasoline. If you are using E85 advancing the timing until knock is encountered will yield poor or catastrophic results. You can go past MBT on E85 and not encounter knock. You might end up damaging your engine.
So I am just looking for how to approach this since I am still learing, thanks
Old Aug 3, 2010 | 05:05 PM
Z_Lancer_Man's Avatar
So what changes did you end up making? I just installed some Cosworth M2 cams this weekend and my car is running like crap. It idles fine (I did up the idle a bit and added timing under low (idle) conditions) but when I put it in gear and touch the gas it doesn't move! It bogs like crazy and builds boost incredibly fast...
Did you take out 3* everywhere? Add any fuel?
Old Aug 3, 2010 | 11:48 PM
EvolutinIX's Avatar
Still making adjustments but so far I pulled 2* over 5K and left fuel alone until I finish the timing changes. Being that I run 91 my fuel target is about .2 richer than the standard 12.5 during spool, 11.5 for peak boost tapering to about 11 at redline. So far I can feel a big diff all over the place. I bumped the timing to 7* at idle and raised the ISCV steps to help the car wanting to stall when going into N coming to a stop, that helped alot. I will post my map when I am "done" to see what everyone thinks.
chaotichoax
Apr 12, 2020 11:55 PM
Clayken234
Mid-Atlantic Region
May 27, 2017 05:15 PM
donaudi
Oct 15, 2010 01:04 PM
RedLanEVO
Apr 17, 2008 02:52 PM
EVO8LTW
Feb 20, 2008 05:56 PM
