Kelford 272 cam install (need input)
Old Aug 7, 2010 | 06:56 PM
donaudi's Avatar
Just installed a set of kelford 272 cams, valve springs, retainers, stem seals, ETS upper pipe (short), ETS intake (no recerc). The car starts idle is horrible and vehicle misfires intermittent. I'm thinking its due to the cams and the intake (everything else being stock). Is this normal or am i looking at other issues.
Old Aug 7, 2010 | 09:49 PM
EvolutinIX's Avatar
Just had the same issue, I would double check you timing. What vacuum is she pulling at idle?
Old Aug 7, 2010 | 09:58 PM
blkmkIII's Avatar
are you tuned for cams?
stock tbe?
Old Aug 8, 2010 | 12:27 AM
joyce1bro's Avatar
^^ +1 you cant just bang in some aggresive cams, turn the key and think everything will be hunky dory lol... That said it should start and idle ok without a tune... I would also double and triple check the cam timing =)
Old Aug 8, 2010 | 02:30 AM
donaudi's Avatar
Cam timing is spot on. Checked it 5+ times during the install. Vacuum is around 10 @ idle. I did find the blow off valve was adjusted all the way out, so i tightened the spring pressure to prevent leak. Also back out the idle adjustment screw quite a bit. She is idling now, though rough (does not stall). While driving it feel butter smooth and great, its just at idle. I'm pretty sure it because he's running on a stock ecu.
It does have an aftermarket turbo back. and I have it idling at 900 - 1000 rpms.
It does concern me that the above post stated that it should idle ok with out tune. It would def stall with out the idle air screw backed out.
Old Aug 8, 2010 | 03:32 AM
joyce1bro's Avatar
well it wont be super ruff but it should start and idle.... I only say that because I changed my cams 2 272s with no tune and it started and I was able to drive it (no boost at all) but it was ok albeit ruff as hell.
Old Aug 8, 2010 | 03:45 AM
donaudi's Avatar
ok that makes . rough idle ok - real rough idle not ok.
Old Aug 14, 2010 | 05:27 PM
4RETECH's Avatar
Kelfords need a tune, 11mm lift
Old Oct 15, 2010 | 01:04 PM
letMeIn's Avatar
its normal without a tune. Car will run like sh$t, and want to stall every time. Tune it
Evoguy!123
Mar 24, 2017 10:50 AM
YNGEVO
20
Jul 2, 2010 11:52 PM
Raceghost
Jul 28, 2009 06:05 AM
racer135
Apr 30, 2009 03:30 PM
Nissan2Evo
Apr 2, 2009 08:03 AM
