Idle Control Problems
#53
no, what I was saying is that this values helped my car to have a very nice idle during stop and decelaration. I personaly didn't make this changes, but my car is idleing fine with this step values but to accuretly change my step values as you notice this are different from the steps of 0715 V7 I had to change scaling into celcius, sorry about the misunderstanding. But if you want to try this values on another car that suffers the same idle problems I am curious if it helps, that's all. Like I said it was a world of difference.
I had to change them to celcius because the 0015 rom don't have the fereinheit scaling.
#54
Oh ok....I got ya.
Thank you for the input. I was under the impression that I made an error in the setup of the 94170715 xml.
You know you can copy the scaling from the v7 into the stock 94170015 and change the table to read in F.
I recommend just going with v7 anyway.
#55
oh yeah I know about the scaling it was just easier to click on temp_celcius on 0715. I am definetly runnin V7 no doubt about it. ![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
off topic. I am impressed how accurate the fuel map cells afr are almost if not exact to the actual afr the car is running so much easier to tune.
#56
off topic. I am impressed how accurate the fuel map cells afr are almost if not exact to the actual afr the car is running so much easier to tune.[/QUOTE]
hi, V7 is worth it.
but, if I understand your post, changing tephra versions has no effect on how your fuel map behaves. It sounds like you did not copy your old latencies over and, lucky for you, the generic latencies fit your car well enough.
hi, V7 is worth it.
#57
in my experience my car started idle like crap after I switched to appauldd 94170715(is great). So today after getting very irritated from stalling last night at every stop and decelaration in neutral, i decided to look at my rom and compare it to the previous 94170015 i was running. Well I first took a look at my idle tables which in the 0715 were in Fareinheit and in the 0015 were in celcius and translated everything into celcius. What I saw is that the higher temp values were off by alot compared to my previous 0015. So I copied all the tables into the 0715
and also the accel enrichment(incorrect) in 0715 from 0015 and now it idles like a champ, close to it anyways. actually it was a little high when rolling in neutral while driving (1050-1150) which I have been adjusting, when the car is parked in neutral is steady 1000rpms. For me something this simple did it. definetly not close to stalling anymore
Thanks Appauldd for this great conversion of the V7.
BTW I run 272 kelford,gt3582hta, recirculating samco bov, injen intake, PTE 1000cc injectors, and a lot other stuff that can alter idle.
![Thumb Up](https://www.evolutionm.net/forums/images/smilies/icon14.gif)
#59
they say to just replace it I just cleaned mine valve with some brake clean and wd40 and it works better but prob should just buy a new one.
__________________________________________________ __________________________________________________ __
ALL SALES BILLET ALUMINUM RADIO KNOB KIT, POLISHED, SOLD INDIVIDUALLY -- Made from 6061-T6 aircraft aluminum; Adds finishing touch to your vehicle's interior; Easy installation
