Plx wideband ?
Old Jul 16, 2010 | 05:36 PM
evo4noob's Avatar
Plx wideband ?
I Have a PLX WIDEBAND
DM5 + SM AFR...
I noticed no support for this wideband with either EcuFlash or EvoScan.
Is there a way to get my wideband to work?
Old Jul 16, 2010 | 11:21 PM
hediki12's Avatar
hey i never got to try this on my friends evo8 yet but try it wire the plx analug 0-5v into the rear o2 (like you would for the lc1 or aem uego) and request id is 3c in evoscan equation is 0.039215686*x+10 try it and let me know how it werk out.
Old Jul 18, 2010 | 07:18 AM
evo4noob's Avatar
thanks bro
has anyone tryed this?
Old Jul 18, 2010 | 07:30 AM
gsrboi80's Avatar
Doing it with my NGK and it works 100% flawless though scaling will obviously be a little different wideband to wideband
Old Jul 18, 2010 | 07:58 AM
hediki12's Avatar
u used the formula i put up?
Old Jul 18, 2010 | 08:13 AM
gsrboi80's Avatar
Not on my laptop but doubtful. The formula will depend on the range of the WBO2 unit you are using.
You have a 0-5v output so if wideband X reads from 9-16 AFR and wideband Y reads from 6-24 AFR you're going to have a different scaling formula for each
Old Jul 18, 2010 | 09:05 AM
turbolarry's Avatar
I'm using a PLX with the 5v output fed to the rear O2. I prefer to see my logs in a spread sheet so my column for AFR uses the formula; v x 2 + 10. It works just fine.
evo8dad
Oct 11, 2013 11:55 PM
DisgustipatedM3
Sep 4, 2013 08:54 PM
jordo
Oct 16, 2012 12:02 PM
tundeclips
Jan 10, 2011 05:10 AM
Links0000
Apr 27, 2007 05:22 AM
