EVOscan love for PLX?
I agree, I really like my M-300 plus PLX has some great customer service. I just had my display box replaced free of charge as it was reading incorrectly despite a new sensor.
Most widebands are pretty straightforward, since he already has the code to do the logging, all he needs is to establish the connection and munge through the data..
The only troublesome widebands are ones that require interaction to start the logging process..
Whats the difference between PLX, LC, and LM widebands?
Thanks
Originally Posted by evo4mad
I can add support for that easy as, just plug it in with evoscan running and send me a wideband csv log file and I'll add support for it.
Originally Posted by C6C6CH3vo
What kind is this?
Thanks
Thanks
So my guess is the PLX is something newer? What type uses a sensor, and mechanism of reading, similar to that by govt controlled emmissions testing machines?
Which type is superior in respect to accuracy (consistant). I'm sure most are precise when standardized and setup propery but which is going to maintain performance?
http://www.fjoracing.com/index.php
MY PLX sensor lasted 2 years, which is decent I think. I have had to deal with PLX regarding a repair to my display unit and they had one of if not the best customer service i have ever had the pleasure of dealing with. In fact, rather than make me wait for them to diagnosis my unit then repair it and ship it back, they simply sent me a new unit, even though my unit was 2 years old
Back to the original topic, what is needed as far as information to implement the PLX sensor into an EVOscan or Mitsulogger log? I know it was mentioned to send the .csv date but, the last log I did had nothing in that column.
What do I need to do to enable that column to get the information that is needed?
the 5v signal is analog.. I have a 5v analog AFR signal (calibrated to the PLX range) hooked up to my ECU+ But for any application to log the data, you have to use a serial output to connect to the computer if its available.
