Hot Start Issues
Old Jul 29, 2010 | 06:54 AM
  #31
l2r99gst's Avatar
Yeah there can be a number of reasons, but adjust the ISCV tables and you should resolve the problem.
Using the BISS to raise the idle may have introduced some of your issues. You most likely should have used the ISCV tables for that as well, but that's fine. As long as your stepper motor has a proper range to work in after the BISS adjustment, then you should be OK. But, that's a whole other story.
For now, just use your ISCV tables like u did for AC on. Also, to be sure that your BISS adjustment didn't mess anything up too much, log your ISC steps at idle, AC off and make sure they are between 2-25.
Old Jul 29, 2010 | 06:55 AM
  #32
widge's Avatar
NO worries i will do that, if there not in that range what should i do?
So instead of increasing idle with BISS i should have just done it with the ISCV tables, oh well we live and learn lol
Old Jul 29, 2010 | 06:56 AM
  #33
l2r99gst's Avatar
We will worry about that later. I don't want to write a novel right now. haha
Edit: Just noticed from your other thread that some of this started from cams and intake install. Depending on what intake, you may need your MAF scaling adjusted. The intake could have been the root of all of your problems. But anyway, just start with what you have now.
Old Jul 29, 2010 | 06:59 AM
  #34
widge's Avatar
The car idles fantastic right now the best its ever done since installing the cams, the weekend for me is in 2 days, im going to work on my hot start first resolve that, then ill log my ISCV when idling and check that its between those ranges, and ill increase the steps in the Desired ISCV Initial Step Position with AC OFF to combat stalling.
Woot i have something to do this weekend
Old Jul 29, 2010 | 03:34 PM
  #35
widge's Avatar
Yeh im going to scale the maf over the weekend i did read that, that can cause stalling issues with cams and intake install, so im going to check my fuel trims and see how far off it is.
Im going to work on my hot start first, then i will check my trims and scale the maf accordingly.
Ill keep you posted
Old Jul 31, 2010 | 12:46 AM
  #36
widge's Avatar
Fixed, AWESOME!!!!!!
Old Jul 31, 2010 | 08:55 PM
  #37
Appauldd's Avatar
Please post your changes.
Old Aug 1, 2010 | 02:50 AM
  #38
widge's Avatar
Ill post my changes when i get home, ill just screen cap the tables,
Cheers
Old Aug 1, 2010 | 11:20 PM
  #39
widge's Avatar
Ok so the changes i made where the following.
To stop the car stalling out when i clutched in i increased the ISCV Initial Step positions in neutral and drive by 10 points.
To solve the cannot start without throttle when warm i decreased the Initial Cranking IPW vs Coolant Temp in the trouble area for me 2.7 worked, this is down from 3.6
Thanks guys
Old Sep 2, 2012 | 02:39 PM
  #40
HsamehH's Avatar
i have the same problem with jdm evo 7 using 98640014 rom,how can i get these IPS vs coolant for my rom ?
RelentlessEVO
Feb 27, 2017 10:02 AM
GeoMitsu
Dec 27, 2015 02:41 AM
sleepy_rps13
22
Jan 30, 2015 10:01 AM
Andy_8
Feb 12, 2011 12:34 AM
EvoIXMR
Nov 19, 2008 04:10 PM
