sd injector dropout problem
Old Aug 19, 2010 | 06:47 AM
gazza19800's Avatar
Question sd injector dropout problem
hi running sd rom id 96533706
car is a evo 8 260 has a billet gt35r forward facing kit and 1000cc rc injectors.
i purchaced a omni 4 bar map and wired it along with a gm temp sensor .
i wired temp sensor to pin 77 and map to pin 73 as i am supposed to
the map sensor i calibrated in sd map sensor and ve calibrations to omni 4 bar etc
i have scaled injectors best i can so far .
the problem i am getting is injectors drop out at around 3 psi of boost at around 3600 rpm , i have logged it and injector pulse width drops off fast and then comes back also obviously the duty follows it . it happens all way up the rpm scale they keep dropping out , map reading etc is smooth and tps is around 45 % and kept steady , they even drop out while being revved parked
does anyone have any idea to help me .
have i missed something ?
i am going to try another rom 96260009 tonight with a e9 map sensor i am going to borrow with scaling for e9 sensor
thanks for any help i need to sort this asap or i am going to pull my hair out haha
gazza
Old Aug 19, 2010 | 07:41 AM
Appauldd's Avatar
I see similar issues on my MAF car in the same area. Feels like the car is misfiring or fuel cutting, or load cutting. The rest of the pull is fine.
Old Aug 19, 2010 | 08:46 AM
gazza19800's Avatar
feels like missfire yes but it goes lean logged it with lm2 as well .
gazza
