Unknown rom id..some help
Old Aug 13, 2010 | 08:30 PM
NOMIEZVR4's Avatar
Hey guys, i have tried searching the previous posts but after 2 hours I just can not figure this out.
I try to use the tephra v7-96530706 for my 2005 evo8 rs and everytime ecuflash says "unknown rom id" than i have to select from three choices.
What I did was take the xml file from tephra v7 and put that into my rom id(96940011). Tried to read from ecu and "unknown rom id" pops up.
I tried to insert the same tephra file into the evo7_base just to play around with it but same darn thing. I know I have to change the hex id once i can get it to open but right now thats my trouble. I don't think this is an issue but when i go to ecuflash and open an old one , go into misc then click on immoblizer it says "D2". So i select all and paste it into notepad and its 53761.
Any help...
I know this is prob a noob question but i tried to do everything i can.
Old Aug 13, 2010 | 09:35 PM
hediki12's Avatar
https://www.evolutionm.net/forums/8531629-post3.html
please put your 9694 xml back to how it should be. if your running vista or windows 7 see the link above.
Old Aug 14, 2010 | 10:03 AM
NOMIEZVR4's Avatar
I put the 9694 xml how it should be and I am using windows xp.
I can read and write perfectly fine with the xml i have right now.
When i try to use the tephra v7 the error message keeps popping up.
Am I doing something wrong...?
Old Aug 14, 2010 | 10:15 AM
NOMIEZVR4's Avatar
Just to be a little bit more specific this is the procedure i am doing..
1. Download the tephra v7-96530706
2. Copy the whole script
3. go to openecu my rom id (96940011) delete everything from it
4. paste tephra v7-96530706 in my rom id- 96940011
5. save it and close the file
6. go to ecuflash and read my ecu
7. then i get a popup message giving the error message
Old Aug 14, 2010 | 10:40 AM
hediki12's Avatar
yes... u dont copy the v7 xml into anything... its not like v5.1
you just put the v7 9653 xml into the folder with all the other xmls
and you will need to run the 96530706 rom that comes with the v7 xml... you will no longer be on 9694 there is no v7 version for it.....
Old Aug 19, 2010 | 09:06 AM
NOMIEZVR4's Avatar
I'm going to try this today and I know this probably sounds like a noob question but what do you mean by "you will need to run the 96530706 rom that comes with the v7 xml"
how will i be able to do that..?
Evo__Lee
Apr 27, 2023 09:34 PM
br3akrboi
Dec 6, 2015 11:40 AM
Anubis18
Apr 11, 2012 08:27 AM
BenjNgo
Jul 1, 2011 02:37 AM
mudduck
Apr 28, 2007 08:04 PM
