how to keep injectors slightly open on decel
Old Aug 31, 2010 | 08:03 AM
ekizenbe's Avatar
anyone know how to do this on ecu flash?
Old Aug 31, 2010 | 09:27 AM
hediki12's Avatar
i think you can but not for long tho they will still shut off. leaving them on longer will result in throttle hang why do you need em on?
Old Aug 31, 2010 | 01:08 PM
VGergo's Avatar
like this thread !! coud be great for ALS -20 degree timing JDM ALS hardware- secondary air system and add fuel will improve the poping sound and increase boost
Old Aug 31, 2010 | 07:43 PM
williillii's Avatar
lol I bet he wants to make his car crackle and pop like a skittle.
kinda curious here too...
Old Aug 31, 2010 | 07:48 PM
C6C6CH3vo's Avatar
All you need to do for decel popcorn is to apply a little throttle. Just use the big toe.
With late enough spark you'll make new friends (hells angles type)
Old Aug 31, 2010 | 08:19 PM
mrfred's Avatar
The injectors do stay open during decel after WOT. This is the factory behavior.
Old Nov 17, 2010 | 09:02 AM
VGergo's Avatar
and how to stay open it for longer time ? :$
Do we know what is the differences between the 4 table ?
- Decel Fuel Cut Delay 1
- Decel Fuel Cut Delay 2
- Decel Fuel Cut Delay 3
- Decel Fuel Cut Delay 4
and what are the numbers in the table mean ? different load how long stay the injectors open on decel ?
What does Decel Fuel Cut Retard doing ?
I have 2 things, on cruesing after let of the pedal first the car goes so rich ~10.5 than how it shoud going to lean and cut of fuel. After wot I didnt see the same things. Maybe it is the idle control valve problem dont know.
But after Wot I would give fuel for the car because ALS Dont know maybe the mr fred patch the closed loop control by wbo2 could help on it ?
Old Sep 3, 2013 | 07:06 AM
ekizenbe's Avatar
Any updates on this? I'd love to get my car to gurgle and pop and bit on decal!
Old Sep 3, 2013 | 01:21 PM
211Ratsbud's Avatar
Switch to sas rom would be easy.
Old Sep 3, 2013 | 01:48 PM
wingless's Avatar
Even easier to throw a block of -1's in the high rpm, low load area of the map if all you want is pops and bangs at lift off??
muhammadali
Lancer Troubleshooting
May 14, 2017 02:30 PM
TxFAkuma
Past Winners / Entries
May 13, 2016 02:18 PM
night crawler
Mar 19, 2016 03:05 AM
Turbojunkie
Northwest Region
11
Aug 20, 2009 01:22 PM
def1
14
Aug 2, 2008 04:48 PM
