Tephra V7 + ICS lamp on USDM
Old Sep 16, 2010 | 08:48 AM
Vigman's Avatar
Question Tephra V7 + ICS lamp on USDM
Hi guys,
Is there someone here who have the dash' ICS lamp working on a IX MR?
I know USDM IX does not have ICS but I was experimenting to see if I could get the light flashing on Alt map with the Tephra V7 and I do not get anything yet…
I wired the pin 90 on the ECU and checked any juice but nothing… no 0V, no 5V, no 12V, never…
May be it is necessary for the ECU to have the ICS switch wired too in order to have the sequence working properly but I don't know if pins 66 and 67 are 0 or 12V managed…
I wonder if someone already worked on this…
I also want to wire the pin 56 to see if it will be possible to control any proper ICS system…
Thanks for any feed!
Cheers,
C>
Old Oct 23, 2010 | 05:10 PM
Vigman's Avatar
BUMP!
Is someone already made the ECU ICS worked on a IX?
Can someone PM me the wiring diagram of the ICS switch from an VIII?
Thanx.
Old Oct 24, 2010 | 02:51 AM
ODUB's Avatar
what is ICS?
Old Oct 24, 2010 | 10:49 AM
drifterific's Avatar
Originally Posted by ODUB
what is ICS?
Intercooler Sprayer. I think he is referring to the light in the gauge cluster that the 8's have.
Old Jul 6, 2014 | 06:11 PM
mirkoelek's Avatar
Originally Posted by Vigman
BUMP!
Thanx.
Did you ever get it to work?
Old Jul 6, 2014 | 07:37 PM
ExViTermini's Avatar
Holy old *** post.
Anyway, the provision for the bulb is there, but that I recall no bub or wiring is present on the evo9.
Old Jul 6, 2014 | 08:50 PM
mirkoelek's Avatar
I added the wire and routed to pin 90 but light does not come on. If I ground same wire then light iluminates. So pin 90 is not seem to be doing anything. I change the maps with tps. I get slow flashing for main and fast for alternate, but nothing happens with ICS. Is there anothet setting i have to turn on to make it work?
Old Jul 7, 2014 | 04:30 AM
Is it enabled in the tephra options?
Old Jul 7, 2014 | 09:13 AM
mirkoelek's Avatar
Yes. Does it have to be above certain load in order to flash?
Old Jul 16, 2014 | 06:15 PM
WRC-LVR's Avatar
Yes there is a setting for the knock and load in order for it to spray and flash. It also must be on the alternate map to be enabled
Load =150 and knock = 1 are teh default setting for ICS light flash
Alchem1st
Mar 15, 2022 08:47 AM
blacktab420
Feb 2, 2016 09:51 AM
dingus
Jul 10, 2015 08:42 PM
besk
Jul 8, 2015 05:27 AM
HyperDisorder
Sep 8, 2011 12:12 PM
