Request for start log with the push of a dash button
Old Oct 12, 2010 | 05:31 PM
Boosted Tuning's Avatar
As some of you may know, in suby land, with their logger (Romraider), they can start the logger by pressing the defrost or rear defrost on the dash. I was wondering if we could get a similar feature working for evoscan.
What you guys think?
Old Oct 12, 2010 | 05:40 PM
hediki12's Avatar
i like!
Old Oct 12, 2010 | 06:12 PM
Raptord's Avatar
Do want.
Old Oct 12, 2010 | 06:19 PM
rgar's Avatar
Yes Please!
Old Oct 12, 2010 | 10:20 PM
drb's Avatar
drb
that would be nice
Old Oct 13, 2010 | 11:38 AM
JohnBradley's Avatar
Setup the hotkey function in EvoScan.
You can use the spacebar or whatever (I use the Alt button) so its fire and forget.
aaron
Old Oct 13, 2010 | 12:43 PM
Fast_Freddie's Avatar
Veteran: Navy
I use spacebar...
Old Oct 13, 2010 | 01:16 PM
aaron
Originally Posted by Fast_Freddie
I use spacebar...
Yes. I know space bar (or any other button) can be used, as I use the space bar.
It just seems like a really good feature and wanted to see if we can get it.
Old Oct 13, 2010 | 02:08 PM
ziad's Avatar
that would mean rom raider was actually running all the time and only logged (saved to disk) on input button press.
Old Oct 13, 2010 | 02:10 PM
That is right. It connects to the ECU, then is reading data, but doesnt log till you press the "log to file" button (or the dash button that start the logging), then it starts saving a .csv file
Old Oct 13, 2010 | 05:08 PM
Benja's Avatar
That's actually not a bad feature, means you would be able to read parameters easily by ticking the box.
Would have to close it down to use Livemap though Z
Old Oct 13, 2010 | 05:34 PM
ziad's Avatar
lol. i dont know, is there any loggable switch?... obviously the ICS button is used by tephra mods...
Old Oct 13, 2010 | 06:00 PM
nytalonTSi's Avatar
That would be cool.
Old Oct 13, 2010 | 06:57 PM
Ceddy's Avatar
The O.P. 2.0 StandAlone logging does similar to what the OP is describing. But still waiting for it to get out of the Beta stage, and get integrated into EcuFlash before it is really usable.
I use the A.C. button, but I have A.C. removed.
There may be some unused binary(on/off) inputs on the 8/9 ecus, but I'm not 100% sure. The older H8 ecus(DSMs, Evo5/6) have two unused binary inputs.
(They were the Base Timing Terminal Pin on old ecus, and the Park/Neutral Switch Pin on Automatics.)
Old Oct 22, 2010 | 07:42 AM
motocooney's Avatar
The fact that Romraider constantly displays values for whatever parameters you have checked is so convenient.
You don't have to log anything if you don't want. You can just watch the screen.
Also, for each parameter checked it shows a min. and max. value for however long Romraider has been running. Whether you were logging or not.
Meaning if you were driving around and didn't feel like scrolling through 5000 lines of log to see what the max knock your were getting. You can just look at the max value.
I know they're 2 different programs but Romraider definately has some advantages as far as being a little more user-friendly.
It would be super cool if someone much smarter than I could integrate some of these features into Evoscan.
