Is there a way to keep the fans running?
Old Oct 18, 2010 | 08:55 AM
StlEvo05's Avatar
Is there a patch or some kind of code that I can enter into my evoscan program to keep the radiator fans running for longer than 5 seconds ? I know that in HP Tuners you can turn the fans on for as long as you want. It would be nice if I could do the same.
Old Oct 18, 2010 | 01:58 PM
vd's Avatar
vd
Yes, there is special tables that control main and AC fans. If you provide ROM ID I believe you'll get sufficient answer.
Old Oct 18, 2010 | 02:47 PM
StlEvo05's Avatar
sweet, i'll post the rom id number when I get home.
Old Oct 19, 2010 | 06:13 AM
StlEvo05's Avatar
Rom ID : 96530706
Old Oct 19, 2010 | 07:35 PM
knochgoon24's Avatar
Here you go. This should work with your ROM.
PHP Code:
<table name="AC Fan Low Duty" category="Fan control" address="2478" type="2D" scaling="Percent (128)">
        <table name="Condition" type="Static Y Axis" elements="2">
            <data>Off -> Low</data>
            <data>Low -> High</data>
        </table>
    </table>
    <table name="AC Fan High Speed" category="Fan control" address="1ad2" type="2D" scaling="VehicleSpeed">
            <data>On</data>
            <data>Off</data>
        </table>
    </table>
    <table name="AC Fan High rpm" category="Fan control" address="1ada" type="2D" scaling="RPMStatLimit">
            <data>On</data>
            <data>Off</data>
        </table>
    </table>
    <table name="AC Fan High coolant" category="Fan control" address="1ade" type="2D" scaling="Temp">
            <data>On</data>
            <data>Off</data>
        </table>
    </table>
    <table name="AC Main Coolant" category="Fan control" address="1ae8" type="2D" scaling="Temp">
            <data>On</data>
            <data>Off</data>
        </table>
    </table>
    <table name="AC Main TPS" category="Fan control" address="1ae4" type="2D" scaling="ThrottlePercentage">
            <data>On</data>
            <data>Off</data>
        </table>
    </table>
    <table name="Fan Counter" category="Fan control" address="1b00" type="1D" level="1" scaling="Hex16"/>
    <table name="Thermo Fan Duty 0-12mph" category="Fan control" address="575c" type="3D" level="2" swapxy="true" scaling="Percent (128)">
        <table name="Conditions" type="Static X Axis" elements="3">
            <data>Main Fan 0-12mph</data>
            <data>A/C Fan 0-12mph</data>
            <data>Main+A/C 0-12mph</data>
        </table>
        <table name="Engine Temp" address="6a14" type="Y Axis" elements="12" scaling="Temp"/>
    </table>
    <table name="Thermo Fan Duty >12mph" category="Fan control" address="45ac" type="3D" level="2" swapxy="true" scaling="Percent (128)">
        <table name="Conditions" type="Static X Axis" elements="9">
            <data>Main Fan 12-31mph</data>
            <data>Main Fan 31-50mph</data>
            <data>Main Fan 50->>mph</data>
            <data>A/C Fan 12-31mph</data>
            <data>A/C Fan 31-50mph</data>
            <data>A/C Fan 50->>mph</data>
            <data>Main+A/C 12-31mph</data>
            <data>Main+A/C 31-50mph</data>
            <data>Main+A/C 50->>mph</data>
        </table>
    </table>
Old Oct 19, 2010 | 11:19 PM
Deepnine's Avatar
logging 0xCF should keep the fan running.
I have tried it some while ago, but i'm not 100% sure.
Just make an new logging item Label it "Fans on" and set the request id to CF, you don't ne full logging speed.
or you enter CF on evoscan at the custom request field.
JDavenport
Apr 29, 2017 12:43 PM
lghtngyello03
10
Jul 22, 2016 03:26 PM
utggevox
Jun 10, 2012 04:30 PM
*02Lancer*
Lancer Aftermarket Forced Induction Tech
16
Dec 3, 2008 06:32 PM
MrB
May 23, 2006 04:24 PM
