EvoECU and 4g94 engine
Old Oct 25, 2010 | 08:43 AM
HornstarBU's Avatar
I've got a similar question to this thread: https://www.evolutionm.net/forums/ec...ngs-4g93t.html
I will be flashing the Evo Rom shortly, and have heard many many different things about the knock settings in the evo vs the lancer. from what I know, the most reliable source tells me:
The stock lancer settings ought to be
single gain = 3
triple gain = 5
all 3 knock multipliers should be = 18
The thread above says otherwise, and I really don't know what the safest way to do this thing is. Plenty of guys have used the Evo ecu with stock settings, just changed maf/injector/idle/fuel/timing settings(and sometimes seeing crazy high knock numbers, not typical with their previous stock rom)....so what do you guys think. Should I adjust the knock settings at all? should i set them to what i think the base lancer is? should i go with the most sensative values and then work my way down ? If so, is the higher the number in knock multiplier mean more sensitive? or is it lower? also, same question about single and triple gain, higher means more or less sensitive?
Thanks for your help
Old Oct 26, 2010 | 10:25 AM
Mitsu.kid.02's Avatar
Im also interested in this question, i have the EVO rom flashed but i havnt touched the settings for the knock
Old Oct 26, 2010 | 12:10 PM
HornstarBU's Avatar
Yeah, and the question is 2 parts.
1 is the "should we see more or less knock in certain areas due to differences in settings"
2 is the "Does anyone really know the true lancer knock settings for our Rom"...roadspike is the only guy i know whose torn into the lancer rom a bunch, and he's where i got my info. I pm'ed him to make sure he got it all right, and to see if he thought those exact settings should be used with the evo rom...but he hasn't responded to my pm thus far, and he sold his evo i think, so he's seldom on here.
Someone's got to know at least the sensitivity and gain questions, like what they do as far as more or less detection of knock. The use of an evo rom is the biggest and best tuning solution we have, but the knock portion has plagued many a 16g base lancer.
nj1266
Jan 25, 2026 01:43 AM
chaotichoax
Apr 12, 2020 11:55 PM
tephra
Aug 19, 2016 10:07 AM
Mitsu.kid.02
Lancer Engine Management / Tuning Forums
217
May 25, 2016 10:47 AM
jfitzpat
Jan 17, 2007 09:32 PM
