Safer to run more boost less timing?
Old Oct 26, 2010 | 10:07 AM
mt057's Avatar
If you are on the stock studs I would not try to go higher than 32psi. I have known a bunch of people taking it that high with no problems on the stock studs. From reading on the forums it sees that most the people I see attempting 35psi on the stock studs end up lifting the head. I guess that at that point cyl. pressure is just to great.
If you are looking for more power. The wmi ,your planning on using, will help you get it. Just don't go for to much torque on that stock block (as I am sure you know). I gained about 70 whp and 50 wtrq at peak gain. I have pics up on my thread called HFS-3 love
30psi is good. No point in pushing it anymore...
Old Oct 26, 2010 | 10:11 AM
binky's Avatar
According to his mod list, he has ARP head studs.
-Bink
Old Oct 26, 2010 | 10:15 AM
mt057's Avatar
lol I just noticed now that you said it...
Turn it up to 37 and tell up how she feels . J/K I think that it would make to much torque at that point. You are now not limited by what the head can hold as much as the bottom end. I would worry more about the rod bolts etc.
Old Oct 26, 2010 | 01:07 PM
5LEEPERISAH23I's Avatar
I think im just going to do 30PSI n call it a day.. untill i build the motor and stuff
Old Oct 27, 2010 | 11:58 AM
EVO8LTW's Avatar
Originally Posted by binky
People will tell you EGT is more or less useless now-a-days because of the wideband O2 sensors. As long as you tune for a certain air/fuel ratio and do not have any knock you will be OK.
However, with that said (guess I can be considered old school on this topic) I like to keep everything around or below 1650 F. Anything above 1700/1750F can start to do some damage.
-Bink
Bink, do you monitor EGT? It's tough to make big power, particularly on pump, on a Black without running hotter than 1650F. I would imagine that the guys putting down 600 whp are way past that. The key to not cooking the turbo is limiting the high EGTs to short bursts so that the components don't actually reach those temperatures.
Old Oct 27, 2010 | 03:52 PM
SLO-EVO's Avatar
Originally Posted by 5LEEPERISAH23I
well stock block can only handle X amount of boost correct?
like going over 30PSI on stock block isnt a good idea right?
It isn't necessarily a bad idea, you just have to remember you are going to be out of the turbo's effeciency.
Old Oct 27, 2010 | 04:40 PM
binky's Avatar
Out of an FP Black's efficiencies range? I think not......
-Bink
Old Oct 28, 2010 | 12:43 PM
SLO-EVO's Avatar
I missed that part. For some reason I was thinking stock turbo.
Old Oct 28, 2010 | 12:48 PM
binky's Avatar
Word
-Bink
Old Oct 28, 2010 | 02:35 PM
C6C6CH3vo's Avatar
I like more boost, slightly rich afr (12.0 - 12-8 to 1), then time it 1 - 2° late of peak power.
This is with no limit to octane
Old Oct 31, 2010 | 06:22 PM
BillSpec's Avatar
Wow everyone please step away from the laptop!
Taking advice from ppl that blow motors on FP blacks at 27 psi lmao.
Go pay for a tune and be done with it.
.02
Old Oct 31, 2010 | 06:44 PM
EVO IXMR's Avatar
.02
I like your thought..
Less * is better then boost but to much of anything can be a bad thing>I would try to have a equal balance..If the block is stock I would run 28 to 30 psi max with lower * maybe 10 to 11* but then again your not gonna make lots of power like that.
Old Oct 31, 2010 | 06:52 PM
wizzo 8's Avatar
gotcha, but if u had to guess. 30PSI with Head Studs, and 100% meth you should be ok. I have a FP Black
Im at 35psi with stock block. I have head studs though.
Old Nov 1, 2010 | 08:22 AM
tumtum411's Avatar
u can a friend of mines is made 515whp(DYNOJET)stock block+meth but u have to change the headgasket but timing is key how aggressive your car do run
Mike/MiTech
Old Nov 1, 2010 | 10:29 AM
BillSpec's Avatar
Finally a somewhat decent post in here.
Not so much 10-11... but just tune it right.
My ix runs hta 35r at 30psi all day stock block with 14* up top with room for more but on pump gas its a gamble. The key is to make sure you are running quality 93 oct. Not some hole in the wall gas station that has not seen a truck in 3 weeks
