Safer to run more boost less timing?
Old Oct 25, 2010 | 08:52 PM
5LEEPERISAH23I's Avatar
is it safer to run more boost like 30PSI with 13 timing
or 17 Timing with 27PSI
Old Oct 25, 2010 | 09:00 PM
binky's Avatar
I always have been a fan of more boost than timing.
-Bink
Old Oct 25, 2010 | 10:06 PM
hediki12's Avatar
depends on the turbo...
less timing= more heat
more boost = more heat
so its kind of finding what yields the best result but i too am a fan of boost over timing
Old Oct 25, 2010 | 11:52 PM
jojobanks's Avatar
Pretty new to the whole tuning thing so sorry if this is a stupid question...
When you're playing with your timing and boost, I understand the main thing you're looking for is knock, but what is an optimal EGT range to look for?
Old Oct 26, 2010 | 06:00 AM
binky's Avatar
People will tell you EGT is more or less useless now-a-days because of the wideband O2 sensors. As long as you tune for a certain air/fuel ratio and do not have any knock you will be OK.
However, with that said (guess I can be considered old school on this topic) I like to keep everything around or below 1650 F. Anything above 1700/1750F can start to do some damage.
-Bink
Old Oct 26, 2010 | 07:06 AM
well stock block can only handle X amount of boost correct?
like going over 30PSI on stock block isnt a good idea right?
Old Oct 26, 2010 | 07:07 AM
-Bink
looking at ur second set up we are making also the same exact power ha
Old Oct 26, 2010 | 07:09 AM
binky's Avatar
It's a good amount of power isn't it? To me at certain times it was scary fast!!
-Bink
Old Oct 26, 2010 | 07:13 AM
-Bink
im putting meth in very soon! need more power!
i ran a 11.7 @120 saturday! "with all season's tires ha"
Old Oct 26, 2010 | 07:25 AM
binky's Avatar
You ran much faster than I did. I don't want to say what my 1/4 mile time is. All I can say is that I apparently am not a very good driver...
What was your 60'?
-Bink
Old Oct 26, 2010 | 08:02 AM
What was your 60'?
-Bink
1.7-1.8
i shift really quick also
Old Oct 26, 2010 | 08:05 AM
binky's Avatar
1.7-1.8
Nice
I am looking forward to stopping the modding for a while once my engine build is done (This way I won't be afraid to break something, since everything will be built to handle it) so I can focus on driving.
-Bink
Old Oct 26, 2010 | 09:46 AM
hediki12's Avatar
that i cant comment on. idk how much boost stock head gasket and studs will take before it lifts.
Old Oct 26, 2010 | 09:57 AM
binky's Avatar
The stock head gasket is good to about 40 PSI.
-Bink
Old Oct 26, 2010 | 10:02 AM
gotcha, but if u had to guess. 30PSI with Head Studs, and 100% meth you should be ok. I have a FP Black
