A Little Tip
Old Nov 5, 2010 | 06:10 AM
lan_evo_mr9's Avatar
I,m just gonna use the "engine load" column. That worked really well and was pretty easy. No extra logging also.
Old Nov 5, 2010 | 06:19 AM
leecavturbo's Avatar
i see trouble a head.
if ppl start doing this whilst load is fairly similar upto peak power after that load drops un proportionately to boost. so ppl will start thinking hmmm boost is tapering like a biatch and start winding up duty to stop it when actually your not looking at real boost
Old Nov 5, 2010 | 08:38 AM
evoRS06's Avatar
I agree, it's cheap for the omni 4 bar and SD is the shiznit!
Old Nov 8, 2010 | 05:45 AM
Vigman's Avatar
Originally Posted by widge
open your log, in the JDM MAP field type in the formula,
=LOAD/6.895-14.7 where LOAD you click on the load cell correspondent to the boost you want to display,
Results can be improved with bar compensated formula:
=((LOAD/6.895)-14.7)*(BARO//100)
This way it will also "work" (aka get close to) in high altitude conditions.
Cheers,
C>
Old Nov 8, 2010 | 05:57 AM
Raptord's Avatar
This.
Or the opposite; my load stays rock solid at 240 from 4500rpm on up, yet boost is dropping gradually from 23 psi @ 4500 to 20 psi @ 7000 (ECU-controlled boost curve)
nj1266
Jan 25, 2026 01:43 AM
silver_evo
Jun 25, 2010 11:31 AM
Pd1
Oct 11, 2009 05:17 PM
HiVoltEVO8
49
May 11, 2006 11:50 AM
