Missfire
Old Nov 8, 2010 | 08:47 AM
EVO IXMR's Avatar
Originally Posted by widge
Ok i put my stock plugs back in the car gapped to 0.5mm (0.019-0.020)
I put my stock ones back in to go back to the stock heat range
The issue is now resolved no more missfire
Told you that gaping them to .19 to .20 will sove the misfire..Glad you got it resolved..
Old Nov 8, 2010 | 01:36 PM
widge's Avatar
Hahaha cheers mate
Old Dec 21, 2010 | 08:26 AM
RJSP's Avatar
I´m having the same issue at similar boost and maybe a little less whp, so just to get it right: You resolved this by gapping to 0.20 - 0.22 AND going back to 7 heat range right? Did you try again with the BPR8ES with the 0.20 - 0.22 gap?
I was running BPR8ES gapped at 0.24 with almost no problems, them the plugs needed changing and I went with BPR8EIX (iridium) and can´t get reliable wot pulls, have tried gaps from 0.20 to 0.25 and no change, changed coils back to stock (curently running Okada Plasma dual coils) and no change. Only momentary cure was to change the plug leads from Magnecor KV85 back to OEM but after a couple pulls the problem was back! So changed back to Magnecor and get the same results, maybe 1 in 5 pulls goes ok.
Thanks for your help,
Ricardo
Old Dec 24, 2010 | 07:45 PM
ZanarkO's Avatar
Dude Im having the exact same problems lol change your spark plug wires
Marik
Sep 23, 2016 08:22 PM
stunt2
Aug 24, 2016 05:17 AM
Dynafit
Nov 4, 2015 01:20 AM
monsta
186
Dec 12, 2009 06:30 PM
hawaiian_evo
Mar 13, 2007 10:49 AM
