stock 05 evo viii load?
Old Nov 9, 2010 | 07:42 PM
2005blackevo's Avatar
hello all as in the title i have a 2005 evo viii all stock just doing some stock logging i searched and couldnt find an answer im only hitting a max load of 180 this seems a little low to everything iv been finding can anyone shed some light on this for me please thanks guys
Old Nov 9, 2010 | 08:14 PM
Raptord's Avatar
180 load is only 9-10 psi on my car... Might be slightly different on yours but still, you should see ~220 I think on a stock car. I'd say make sure your boost lines are connected properly and that the stock boost pill is in them, otherwise you'd only be boosting to wastegate pressure (~14 psi) which could be around 180 load on a stock car. Also check for boost leaks while you're at it.
Old Nov 10, 2010 | 05:18 AM
We'll Iv done a boost leak test and fixed all the leaks I don't know about the pill tho hopefully have gauges in this weekend to see what im hitting
Old Nov 10, 2010 | 04:25 PM
ok guys got boost gauge in im hitting and holding right at .8kg/cm2 which is about the equivalent of 11psi take in consideration the gauge being off by about 3 psi that makes it right at 14 which from what said above means no boost pill which means pervious owner prolly had a boost controller on here and lost old lines and just put vaccum lines on sound about right to anyone thanks for your help
Old Nov 10, 2010 | 05:25 PM
Raptord's Avatar
Sounds right to me. So you have the choice of either getting some stock vac lines or just get some form of boost controller. Since you're going to be buying something either way, I'd recommend just going with the boost controller and be done with it.
city
Jun 2, 2017 08:34 PM
tim85851
MitsubishiParts.net - WA
10
Jan 7, 2015 09:35 AM
Anonymouse
For Sale - Cars For Sale
21
Jul 15, 2012 02:24 PM
Joey B
Northwest Region
10
Nov 25, 2011 08:26 AM
NYC EVO
13
Oct 21, 2010 07:23 AM
