Accelation enrichment
Old Nov 17, 2010 | 03:15 AM
EvoPower81's Avatar
Acceleration enrichment
Hey Guys I have been doing some extensive reading with respect to "accel enrichment" but have found any conclusive information on which tables actually control this. I am using the 90550001 ROM. My car hesitates during gear shifts and touching the throttle after decel. My afrs are lean during this which I think is due to the cams rushing in more air than stock as soon as the throttle plate opens. Is it the "Accel Enrich Base Vs. eng temp" And/or " Decel Fuel Cut Resume Enrich" And /or "Accel Enrichment" table that need to be adjusted. Note this is only in the cruise areas mostly
Old Nov 17, 2010 | 10:57 AM
thermaldynamics's Avatar
I had a problem like you and I seem to have made it better by increasing the "Async Accel Multiplier vs TPS Delta". My problem was only during lower amounts of tps input when rowing through the gears during daily driving (like accelerating in traffic from a stop). I increased the first 3 rows (labeled "factor") by 15%, increased the middle 3 rows by 12.5%, and the last 3 rows by 10%. I haven't tried fine tuning it yet to see if I can make it better or worse by going the wrong way with the values. I don't have data to support it is working better yet as I literally just made the change yesterday, but so far it "feels" better than it was a few days ago...
I am using 96531706 so I don't know if this table is defined in an xml for your ROM.
Good Luck and let me know if it helped or hurt your situation.
Old Nov 18, 2010 | 06:03 AM
EvoPower81's Avatar
my rom is 90550001 and i dont see it defined
curamrdan
Aug 19, 2018 04:31 PM
211Ratsbud
Mar 23, 2014 02:03 AM
curamrdan
E85 / Ethanol
Sep 24, 2013 08:08 AM
jameswwt
Oct 19, 2012 11:21 PM
utripin
Feb 17, 2010 09:52 PM
