why does closed loop refer to maf?
Old Nov 26, 2010 | 02:38 AM
leecavturbo's Avatar
as well as lambda for closed loop idle
why in many many threads about lean idle do all the advise mainly point to a boost/vacuum leak?
surely its irrelvant what air flow is at idle?
all we need is lambda sensor to tell the ecu whats what surely?
Old Nov 26, 2010 | 08:53 AM
jcsbanks's Avatar
Before the lambda sensor(s) come on line (fail) or you'd have no information other than throttle and engine speed to fuel and time the engine.
Additionally, throttle transients would be rubbish. Closed loop works much better when the open loop calibration is tight.
Better to calculate the engine load with the slug of air about to hit the engine, rather than on what just happened.
Old Nov 26, 2010 | 10:32 AM
i can see that john but surely at only anything over 0% throttle there is going to be drastic blobs of air? so at idle and 0%tps we just adjust afr off lambda feedback?
Old Nov 26, 2010 | 12:21 PM
Ceddy's Avatar
The Narrow Band O2 is slow to respond, it takes almost a second to swing from rich to lean, it doesn't provide enough real time feedback.
Also you still need to how much air is entering the engine.
The amount of air entering at Closed Loop at Idle (-20 Hg) and Part Throttle(-1 Hg) can be very different.
Old Nov 26, 2010 | 01:51 PM
where not talking about anything other than 0% tps though
isn't sd just monitoring lambda at idle or is that still taking map into concideration?
if so it wouldn't have tables based around the vacuum surely so the map will only give "its in vacuum"
Old Nov 29, 2010 | 02:08 AM
jcsbanks's Avatar
It is based on airflow meter measurements or SD calculations to simulate it. Just because you've not moved the throttle doesn't account for air temperature, air density and the position of the idle speed control valve.
Trying to do this would be like trying to steer your car from the trunk using elastic bands.
jcsbanks
Mar 8, 2011 04:15 PM
rovanpera
Mar 5, 2011 04:40 PM
SeanV
Oct 7, 2009 09:35 AM
crcain
Sep 14, 2009 01:56 PM
dakar
Jan 8, 2008 12:13 AM
