Knock Tables
Old Dec 6, 2010 | 05:50 PM
EvoPower81's Avatar
Knock Tables
Hey tuners can you tell me if you guys consider the stock knock tables too sensitive?. In what situations other than false knock from engine harmonics do you adjust the tables and actually make more power from the tune?
Old Dec 6, 2010 | 06:27 PM
Raptord's Avatar
I don't think the stock knock tables would be too sensitive on a stock motor. Unless you have aftermarket internals, you normally shouldn't have to mess around with those tables.
False knock is the only reason you want to adjust them; a knocking engine won't make more power than one that is properly tuned to not knock, and even if it does, if the ECU isn't adjusting the timing to keep the knock under control, it'll only have that extra power until something goes boom...
Old Dec 6, 2010 | 06:32 PM
naplesevo's Avatar
yes sometimes you can have an overly sensitive knock sensor and if so you can always turn it down a little but never to much after all it is there for a reason
Old Dec 6, 2010 | 06:53 PM
tscompusa2's Avatar
what cams do you have ?
Old Dec 6, 2010 | 10:41 PM
EvoPower81's Avatar
JUN 272. BTW I not trying to suggest this might be the case with my car or tune Im just curious to find out what conditions one would adjust their tables.
Old Dec 7, 2010 | 08:02 AM
Andy_8's Avatar
Everytime i go to my tuner to get tuned i lift the knock threshold line out of the way by raising the multipliers, let him do his thing on Det cans and then drop the multipliers back down until i start to see 1 or 2 counts. I then know i have a sweet tune and knock protection from the ECU in the event of bad fuel or unusual load.
Built engine
Andy
Old Dec 7, 2010 | 09:50 AM
EvoPower81's Avatar
Built engine
Andy
Is the knock tables reset to stock after? If so , you could have left them in the first place as they would have been working accurately I guess
Old Dec 7, 2010 | 10:18 AM
crewdawg130's Avatar
Det cans FTW. Specialy on built engines
Old Dec 7, 2010 | 10:51 AM
LGshow19's Avatar
what are DET cans?(detonation)?
Old Dec 7, 2010 | 10:54 AM
tscompusa2's Avatar
headphones with a mic attached to the block to pickup "pinging"
Old Dec 7, 2010 | 10:56 AM
tscompusa2's Avatar
Not sure. Ive had phantom knock on my 2.3L, but i was on e85 so much easier to adjust the knock filter settings safer on a high octane fuel to confirm it is indeed false knock detection.
to answer your question; you adjust the knock MULTIPLIER tables.
Old Dec 7, 2010 | 07:37 PM
Andy_8's Avatar
No, but enough to provide safety cover just infront of the tune.
I would be horrified if a tuner was not using det cans when he tuned my car. Infact if he wasn't he would not be tuning it and i would be going back.
Bob_tm
Jan 5, 2018 04:45 AM
Smogrunner
Jun 26, 2017 03:54 PM
Rado_93
Oct 23, 2015 11:48 AM
jcsbanks
Jun 21, 2013 03:29 PM
AIK
10
Sep 13, 2010 02:48 PM
