Knock tables with Built Motors
Old Oct 11, 2011 | 11:54 AM
JohnBradley's Avatar
You are still trusting the sensor to determine raw counts and it is better than nothing if you dont have the experience. Voltage is amplitude so you get a better idea. It will work for alot of cars but you will get to a point where nothing works other than looking for spikes. After that the next level knock control is really custom. Thats why I still read plugs when on gasoline.
Aaron
Old Oct 11, 2011 | 11:57 AM
BigT's Avatar
Aaron
Ugh, and there aren't any good off the shelf electronic DET Can setups out there.
Old Oct 11, 2011 | 12:58 PM
wreckless969's Avatar
Thanks for the bump Aaron, great info.
Old Oct 12, 2011 | 12:58 AM
stunt2's Avatar
Originally Posted by BigT
What about merlin's formula for determing phantom knock? You have to log KNOCKBASE and KNOCKFILTADC and compare on a line graph.
aren't these two same as Knock Sum and Knock Voltage in evoscan ?
and also, what rpms correspond to knock mulipliers Low, Mid and High ?
Old Oct 12, 2011 | 08:27 AM
Mauricio Evo IV's Avatar
Interisting!! I have problem with knock!! I don´t know if is phantom or what!!
I change everything in my car! Finally I change the load knock scale to finish my tune...
Old Oct 12, 2011 | 02:29 PM
Low is up to 3800
Mid is up to 5600
High is 5600+
Old Oct 12, 2011 | 03:22 PM
wizzo 8's Avatar
My motor doesn't knock more with my built motor. Although once in a while around 2500rpm I get some minor knock on normal acceleration.
Old Oct 12, 2011 | 03:43 PM
Some dont that is true. Our Tech Jake's 2.4 is absolutely silent, his knock control is stock.
Old Oct 13, 2011 | 06:05 AM
Dynotech Tuning's Avatar
I use knockfiltadc and knockbase in DMA to accurately catch the spikes. Also, I don't think the mid,high switching points are 5600. I have changed my knock multipliers on the 8's to 20/50/100 to confirm and I generally see the switching point at 6800rpm in my logs.
I use the electronic det can system made by PHORMULA and it works great, although I recommend a FRESH 9v battery during each listening session since low battery voltage seems to allow more static noise into the signal path.
-Jamie
Old Oct 13, 2011 | 08:59 AM
Good to know Jamie. I will have to look into that, DMA boosts log speed to 62500?
Aaron
Old Oct 15, 2011 | 06:17 AM
wwcagedevo8's Avatar
Depending on the suspension, a bump in the road can set the knock sensor off. You will always get some knock down low cruising and accelerating. It only really matters when the car is getting into boost and going full boost. Other than that the car is picking up other stuff and is not real knock.
Old Oct 15, 2011 | 06:41 AM
Aaron
Yeah, I know you can change the baud rate in a regular rom to 62500 but if I recall, it really only doubles the samples per second. Have you ever tried DMA Aaron?
-Jamie
(aka Jack_of_Trades)
Old Feb 5, 2012 | 03:05 PM
Carloverx's Avatar
Would octane booster suffice for testing is knock is phantom?
Aaron, how aggressive did you have to get with your tables?
Thanks.
Old Feb 5, 2012 | 03:20 PM
Raptord's Avatar
Personally I wouldn't rely on it.
Old Feb 6, 2012 | 08:39 AM
Octane booster only raises the octane by a few points. If it says it raises the octane by 4 full points, that means it raises 93.0 octane to 93.4, not 97. It's a joke of a product really. 100 octane unleaded race gas, Would be more helpful.
-Jamie
