evo ecu ICS light output
Old Feb 9, 2011 | 06:13 PM
burnzy's Avatar
is there a pin on the ecu we can tap into for an LED to use with the TPS map switch, the evo 6's don't have a water spray light and was hoping to use an led in place of the flashing ICS light if thats possible.
Old Nov 7, 2011 | 03:05 AM
evoyrrah's Avatar
Bump......anyone???
Old Nov 7, 2011 | 09:00 AM
charlie.tunah's Avatar
Why not just wire up an external switch, with a led in the circuit? Instead of using the tps as the switch...
Old Nov 8, 2011 | 04:21 AM
stunt2's Avatar
how exactly can it be done ?
Old Nov 8, 2011 | 09:21 AM
http://evoecu.logic.net/wiki/Map_switching_harness
And I believe there are a few guys that make these harnesses. Jamie (Dynotech Tuning aka Jack of Trades) used to make them. He may still
This is also the way to incorporate fail safes from other systems, like meth.
