How to set min temp for closed loop ?
Old Feb 13, 2011 | 12:07 PM
stunt2's Avatar
Question How to set min temp for closed loop ?
As above, in EcuFlash can't see anywhere this option, do I need some changes in xml ? if yes, what kind of changes
Rom ID: 96530006
Old Feb 13, 2011 | 10:14 PM
stunt2's Avatar
nobody knows it's adress ?
Old Feb 13, 2011 | 10:55 PM
92LaserRs's Avatar
Are you getting P0125?
Old Feb 13, 2011 | 11:00 PM
stunt2's Avatar
yes
any suggestions ?
Old Feb 13, 2011 | 11:30 PM
justastockevo's Avatar
has to do with periphery bits here on EDM cars, just try using corresponding tephra rom and don't mess with periphery.
Old Feb 14, 2011 | 12:53 PM
EvoRuss's Avatar
Load up a tephra rom and you shall see that p code no more my friend.
Old Feb 14, 2011 | 01:33 PM
todd6027's Avatar
<table name="Min Coolant Temp for Closed Loop" address="15aa"/>
Old Feb 15, 2011 | 01:53 AM
EvoDownUnder's Avatar
read here https://www.evolutionm.net/forums/ec...g-trims-2.html
Old Feb 19, 2011 | 03:07 PM
stunt2's Avatar
thanks guys
Old Feb 20, 2011 | 06:03 PM
Did it solve your your problem with the P0125. Cause it didn't work for me
Old Feb 21, 2011 | 02:24 AM
grayw's Avatar
If you are using the same rom ID, have you disabled the rear O2 using the periphery bits?
The solution as posted by Reclipse07 is to use the Tephra version of the rom and disable the O2 sensor in the options.
Old Feb 23, 2011 | 02:16 PM
stunt2's Avatar
I have Tephra rom, tried O2 simulator On and Off, also tried via periphery bits, but code still comes on
haven't lowered that value yet...
grayw
I've disabled it but no luck
is there anything else that can trigger P0125 code ?
Old Feb 23, 2011 | 02:35 PM
do it via tephra options only.
don't mess with periphery for this matter.
don't touch periphery bits, make sure rear o2 check is ENABLED in periphery (copy value from the stock rom) AND rear o2 sim is enabled too in tephra's options.
clear the code, then it should disappear.
i'm 95% sure you're confused with the rom settings. 5% still remains, so i'll ask just in case - which thermostat/radiator do you have?
Old Feb 24, 2011 | 07:00 AM
grayw's Avatar
As above set all the periphery back to default values to start with, you might get some other odd CEL's such as EGR that will need disabling via periphery as you are running it in an Evo 3.
Old Feb 24, 2011 | 11:13 AM
stunt2's Avatar
justastockevo
in my rom "FAA bit.1: Rear O2" is disabled and "RearO2 sim." is enabled from tephra options. should I just enable "RearO2" from FAA bit and also leave simulator from tephra options enabled ?
stock Evo3 radiator and stock thermostat
graw
I have EGR valve blocked off even before ecu swap. when I swapped the evo8 ecu and first started the car, there was continious ticking sound from egr solenoid. just disconnected the plug from solenoid and no ticking sound and no CEL
