How to set min temp for closed loop ?
Old Feb 24, 2011 | 11:34 AM
justastockevo's Avatar
are you really running that ecu on evo 3? that changes the case, you should have told that before.
please check the periphery, if problem persists try logging your coolant temp. that should shed some light on your trouble.
Old Feb 24, 2011 | 11:43 AM
stunt2's Avatar
justastockevo
yes, on E3 mate
just checked the rom and "FAA bit.1: Rear O2" is disabled and "RearO2 sim." is enabled from tephra options.
should I just enable "RearO2" from FAA bit and also leave simulator from tephra options enabled ?
Old Feb 24, 2011 | 11:44 AM
grayw's Avatar
Set all the periphery bits back to the default values, the P0125 is caused by incorrect disabling of the rear O2, it has nothing to do with coolant temps.
The EGR CEL was just an example of a possible fault, as some of the periphery will need to be changed to stop CEL's on the E3.
Old Feb 24, 2011 | 02:43 PM
faa bit 1 should be set to 1. otherwise you'll have p0125
Old Feb 24, 2011 | 10:55 PM
stunt2's Avatar
Thanks
I'll try
EvoSeanzie
Nov 19, 2024 11:48 AM
cstylez52
May 19, 2011 10:20 AM
440 4x4
Oct 12, 2005 08:25 AM
