Looking to buy an evo 8 that needs a few things
Old Feb 20, 2011 | 12:34 PM
cefaln452's Avatar
I am looking at this evo that needs a transfer case and ECU since he started to part the car. It is all it needs. I have the question about the ECU issue.
Can I just buy a used ecu and plug it in and the car will fire up or is there a case learn? If so let me know what's involved and what needs to be done.
Thanks
Nick
Old Feb 20, 2011 | 12:36 PM
06RedRalli's Avatar
No the ECU has to be flashed to use the immobilizer that is currently in the car...without the correct settings in ecuflash the car will not start...
I know there is a way to disable the immobilizer, check around the ecuflash area to find this info...
But you'll have to get the ecu flashed before it'll start.
Old Feb 20, 2011 | 12:39 PM
cefaln452's Avatar
I dont want to do this but, what if I were to buy a ecu, immobilizer, key, ignition from a different car (being from the same car)
id rather find a way that I can use the key that comes with the car as it is the same key for the door and the trunk
Old Feb 20, 2011 | 12:58 PM
EvoJoeIX's Avatar
why would you go through all that work when all you have to do is plug in a latop and enter in 4 numbers... its not hard to do at all
Old Feb 20, 2011 | 01:22 PM
cefaln452's Avatar
because I dont have the scanner... which one should I invest in?
Old Feb 20, 2011 | 01:36 PM
cefaln452's Avatar
or who could I send the ECU to, to do so?
Old Feb 20, 2011 | 02:34 PM
EvoJoeIX's Avatar
you could send the ecu to anyone who can tune, but he problem is you need to know the immobilizer code of the car the ecu is going in
Old Feb 20, 2011 | 04:03 PM
cefaln452's Avatar
and how do I obtain that?
Old Feb 20, 2011 | 04:17 PM
EvoJoeIX's Avatar
you would need the ecu that goes to the car your trying to use, plug in a laptop, find the code, then put that code into the ecu your trying to put into the car
Old Feb 20, 2011 | 04:40 PM
cefaln452's Avatar
ok, the issue is I dont have an ecu in the car. I am needing to buy one.
Old Feb 20, 2011 | 05:22 PM
EvoJoeIX's Avatar
then your gonna need to bypass the immobilizer. id talk to a tuner or someone who knows how to do that for you
Old Feb 20, 2011 | 05:33 PM
cefaln452's Avatar
do you know if there might be a way to read the immobilizer thats currently in there?
Old Feb 20, 2011 | 05:54 PM
cefaln452's Avatar
I just read that all I need is to buy a "new" ecu and once I install it, the dealer will have to sync the immobilizer and keys then it will start. YAY
now i just need to get my hands on a t-case, ecu, radiator with fans and MAF
nudge120
May 14, 2020 06:18 AM
Migsubishi
For Sale - Part Outs
May 16, 2016 10:15 PM
dillons13
AEM EMS
Jan 20, 2016 08:52 PM
skills
May 4, 2013 05:07 PM
