Can't remove boost cut
Old Aug 1, 2011 | 02:01 AM
burgers22's Avatar
Originally Posted by pranil
i have a evo5 just bgt it 3months ago..im having promble with boost cut..m car is standard and it gives a boost cut on 15psi..what can i do??please help
I'd suggest you post your ROM at www.geekmapped.com this forum mainly covers Evo 7-9
Boost cut actually works on the calculated load, so 15 Psi shouldn't cut on a totally standard car. How are you measuring boost? It could be you have a boost leak, any changes to exhaust or inlet can change the boost or load.
Old Aug 1, 2011 | 06:30 AM
GStarr's Avatar
Post#1 bump...
Old Aug 1, 2011 | 01:20 PM
wreckleford's Avatar
Originally Posted by RoadSpike
Found what i think is the fuel cut load table
There are two of them probably the 1-3 gears and 4-5 gears like the rest of the maps.
Map 1:
3A48
Map 2:
3A58
<table name="Fuel Cut 1" category="Fuel" address="3a48" type="2D" level="1" scaling="Load8">
<table name="RPM" address="5a70" type="Y Axis" elements="9" scaling="RPM"/>
</table>
<table name="Fuel Cut 2" category="Fuel" address="3a48" type="2D" level="1" scaling="Load8">
</table>
The XML I have has the maps grouped as 1/2 gear and 3/4/5. Can you confirm that it is 1/2/3 and 4/5?
haulass221
26
Jan 18, 2009 10:09 PM
george3
33
Nov 23, 2008 09:57 PM
bigboybusa
17
Oct 16, 2005 07:22 AM
MysticMyth
Aug 4, 2004 10:44 AM
evil8
Sep 22, 2003 07:01 AM
